Jack Location
The screw jack is operated by a long crank handle that could be folded in half for EZ storage.
Originally...if the spare was mounted at the rear under the truck, Ford put the jack inside the spare tire's wheel.
Otherwise the jack was placed inside the cab, either behind or under the seat. Nothing was used to secure it...it just sits there.
The tire iron (C1SZ17035C) and the long folding crank handle (82Y17081B) were placed behind the seat.
If someone has the crank handle that is the one piece non folding type, that's the one used after 1966 (C7TZ17081A).
Not sure if it's the info requested, swapped out for underneath when I had to replace driver's side rear fender and could not find replacement fender with the indentation for the spare. Anyhow, as pathetic as the the pic's are, posted them for another member with simular question. It's difficult to tell from pic's but the long bolts are secured to the frame, 1 end of the bracket is secured close to the rear of the driverside tire and the other end of the bracket is secured to the frame using a long bolt with an eye hook, once the tire and bracket are lifted into place the eye bolt fits thru a corresponding slot in the bracket. I use a safety clet to make sure the bracket and tire stay secured underneath the bed. Imagine the placement can vary, suggest setting the tire with bracket to desired location and mark the location for the bolts. I would not be surprised if the holes are not already drilled in the frame. Also, suggest double nut, or use a locking type nut making sure the bolts are secured to the frame. Also have 65 lwb and seem to recall the bracket is longer, I am certain a more knowledgeable member can advise if there bracket comes in different lengths. Anyhow , when you get a chance look underneath the how's will be fairly clear.
http://i300.photobucket.com/albums/n...s/IMG_0009.jpg
http://i300.photobucket.com/albums/n...s/IMG_0004.jpg
kirbyg53
1997-2006 Expedition & Navigator
08-06-2014 07:01 AM
