no start: turn key, hear click, all power cuts out
94 f250 5.8
the truck has a brand new starter (the problem happened with the old starter too) and the battery is fully charged
when i turn the key, i hear one single click and the power cuts out. i can't attempt a second start or turn on the lights or have any power going through the truck until i disconnect and reconnect the battery. then ill get back in and try again and it cuts out again. anyone ever run into this?
could this be the coil? im pretty new to domestics but from what i understand, the coil sends cranking juice over to the starter after the initial burst of current. does it sound like im on the right track?
thanks a lot in advance
Could simply be a bad battery. How old is it. Sometimes they show 12 volts or even a "full charge" but aren't putting out enough amps to crank the vehicle. Could also be the battery terminals as mentioned earlier. I've had this happen on my Camry. Turn the key...hear a click and all goes dead. Nothing happens until I jiggled my pos. terminal connection...then she would crank right up. Most likely one of the two or a combination of both.
Rattlesnakebyte
Electrical Systems/Wiring
01-29-2016 09:52 PM
frustrated mechanic
2004 - 2008 F150
19
06-10-2015 04:15 AM
alpine7572
1997 - 2003 F150
10-30-2005 10:40 AM
