am /fm 8 track cb radio ??
Old 04-05-2009, 09:04 AM
428HIGHBOY's Avatar
428HIGHBOY
428HIGHBOY is offline
I just picked up a new parts truck (1979 f-150 ranger Lariat). It has the factory am/fm 8 track with cb. I was wondering how rare this option is and if it is worth anything? I am thinking about using it in my project. One other thing is, the anntana is broke off, does this require a special anntana? It looks like the radio and cb use the same one?? Any diagrams out the on how this should be hooked up?
Old 04-05-2009, 10:45 AM
rbaker6336's Avatar
rbaker6336
rbaker6336 is offline
the antenna is same as AM/FM
Old 04-05-2009, 10:55 AM
428HIGHBOY's Avatar
428HIGHBOY
So did the cb use the same antenna?
Old 04-05-2009, 11:00 AM
rbaker6336's Avatar
rbaker6336
yes the CB uses the same antenna
Old 04-05-2009, 11:20 AM
428HIGHBOY's Avatar
428HIGHBOY
does the cb have to be used with the factory stereo or can it be used with an aftermarket one?
Old 04-05-2009, 11:25 AM
Dr. Dirt's Avatar
Dr. Dirt
Dr. Dirt is offline
I know that the radio and cb use the same antenna, but I don't think it's the same as a regular AM/FM antenna.
Dr. Dirt's Avatar
Dr. Dirt
Dr. Dirt is offline
I think it has to be used with the factory radio.....not sure though.
Old 04-05-2009, 11:46 AM
rbaker6336's Avatar
rbaker6336
it is the same,I had to change the antenna on my '79 town car
Old 04-05-2009, 12:06 PM
Jermafenser's Avatar
Jermafenser
Jermafenser is offline
No, they are not the same. The CB antenna is a special tri-band antenna which is hard to find today. The correct antenna for the factory CB and factory radio use the same CB antenna.
8-track was not available on F-series.
Old 04-05-2009, 03:36 PM
ranger429's Avatar
ranger429
ranger429 is offline
Ditto on all of the above. There is a seperate AM/FM/CB antenna that was used. A regular AM/FM antenna will not work with the factory CB.
No 8 track and no cassete player stock. Post a picture of this setup that you have 428HIGHBOY.
AM, AM/FM or AM/digital clock were the only options.
Factory AM/FM/CB antenna, about as hard to find as that needle in a haystack.
Old 04-05-2009, 03:56 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
81-F-150-Explorer is offline
Well, before 1980, and after 1983.
There were Ford Dealer add on kits that bolted under the dash, but that's a different discussion.
Old 04-05-2009, 04:04 PM
81-F-150-Explorer
According to the 1979 wiring diagrams, if the truck is equipped with a AM/FM stereo, the CB is independant of the radio, bar the antenna.
Center dash Speaker is wired for CB, and door speakers are wired for stereo.
On AM or AM/FM mono radios, the Center dash Speaker is used for both CB and radio. When the CB is on, it cuts the normal radio off.
You can hook up a regular CB antenna to the factory CB radio as an option as well, then use a regular AM/Fm antenna for the stereo. Then they can be totally independant units. However it's not factory that way, which probably defeats the purpose.
Old 04-05-2009, 06:17 PM
428HIGHBOY's Avatar
428HIGHBOY
Well it dont have the antenna so I cant pick up any signal but i can tell that the cb is coming through the center speaker and the radio is in the doors. I will try to get some picks posted. thanks guys.
Old 04-05-2009, 06:29 PM
shameless's Avatar
shameless
shameless is offline
if your wanting info on a cb. heres another forum I'm on for cb and ham radios.
QS C.B./Ham Radio Forum (Quack, Quack)
Old 04-05-2009, 06:33 PM
428HIGHBOY's Avatar
428HIGHBOY
YouTube - 1979 F-150 am/fm 8 track w/cb
I took a short video of it. If you look close you can see the ford logo on the cb.
Quick Reply: am /fm 8 track cb radio ??
