Can I turn my power locks into keyless entry if it wasn't OE?
I am sure you probably can something aftermarket. But it's a lot of wiring cutting and splicing, and if you find something you are interested in, look up the instructions on the web, and look for anything special for a Ford installation. Fords usually require extra wiring and possibly some relays to make the locks work.
Bulldog Security sells keyless entries AND remote start with harness. Usually no wire cutting involved. I used to take all the time wiring them up manually but since they added the harnesses for most models, I went that way on my 2000 and so I don't use the factory remotes anymore. The OEM remotes won't unlock the doors when the motor's running.
Pretty cheap too.
Pretty cheap too.
WarrensE350
27
04-11-2014 07:05 AM
Brians97F250Crew
24
01-10-2014 06:24 AM
waldreps
12-23-2006 09:50 AM
