Pioneer avic install help!!
Old 04-04-2009, 04:57 PM
RAM7880's Avatar
RAM7880
RAM7880 is offline
I am looking to install a pioneer avic f series into my 05' f150 Screw,was wondering if anyone had any info on any wiring harness's that will work with the factory speaker system w/sub woofer (audiophile option)
thanks
Old 04-04-2009, 08:05 PM
ReAX's Avatar
ReAX
ReAX is offline
Radio 12v lt. green/purple + radio harness
Radio Ground black and black/lt. green - radio harness
Radio Ignition pink/black or lt. green/yellow + radio harness
Radio Illumination lt. blue/red (dimmer) + radio harness
Factory Amp Turn-on dk. green/purple + radio harness
Notes: This is the subwoofer amplifier turn on lead. The subwoofer and amp are in the driver side rear corner of the cabin. The subwoofer speaker wires are brown/orange (+), and red/black (-) at the radio harness.
Power Antenna N/A
LF Speaker +/- orange/lt. grn - lt. blue/wht +,- radio harness
RF Speaker +/- white/lt. grn - dk. green/org +,- radio harness
LR Speaker +/- gray/lt. blue - tan/yellow +,- radio harness
RR Speaker +/- orange/red - brown/pink +,- radio harness
Metra shows a pn 70-5521 for the factory integration harnesses.
Description
Factory amplifier integration harness (Click on part for more details)
Product Specifications
* -Factory Amplifier Integration harness
* -2 RCA plugs to mate to aftermarket radio's pre-amp outputs
* -One 24-pin power plug and one 8-pin subwoofer plug
* -A 1.5K Ohm resistor can be used on the amp-remote wire to eliminate turn-on pop.
Allows installation of an aftermarket radio using the existing factory wiring and connectors. No cutting of factory wiring is needed.
Old 04-05-2009, 08:43 AM
meb9796's Avatar
meb9796
meb9796 is offline
hey, I installed one in a 02 Explorer sport and the folks at AVIC411.com were a lot of help both with the install and with any other questions you may have.
Old 04-05-2009, 10:51 AM
RAM7880's Avatar
RAM7880
RAM7880 is offline
thanks for the info, cant wait to try it out!
Old 04-06-2009, 09:19 AM
TxFireman1972's Avatar
TxFireman1972
TxFireman1972 is offline
definitely check out AVIC411.com, lots of good info over there. Be careful, they are a little tough on new guys sometimes lol
bobv60
1999 to 2016 Super Duty
10-21-2015 06:13 PM
PostRelease
2009 - 2014 F150
11-02-2009 01:51 PM
Pittsburgh-05HD
07-05-2007 11:43 AM
trojanman1
133
08-22-2006 09:53 PM
Quick Reply: Pioneer avic install help!!
