maximum trailer towing
tbejr:
Sorry, I can't give you exact numbers but I did want to
say welcome to the site.
First thing I can tell you is to forget about the bumper
for a hitch use a receiver hitch, much more stable.
Secondly, I don't see any reason you couldn't pull a 4000
to 4500 lb trailer.
Jim.
2000 F-250 XLT SUPERCAB 7.3 PSD 4X4 AUTO, LIGHTED VISOR, ROLL TOP COVER, BLACK AND BEAUTIFUL. I JUST LOVE A FORD TRUCK.
to 4500 lb trailer.
Jim.
[font size="1" color="#FF0000"]LAST EDITED ON 04-Mar-01 AT 01:38 PM (EST)[/font][p]I also have a '70 F100 with a 390 C/6 and 3.50 gears, gvw 4,400# and I've done quite a bit of towing with it. I think your brakes will be your limiting factor. I have manual drums, and once they get hot, they're pretty useless. I have a 24' pontoon that weighs in at about 3000# with the trailer and the truck has no problem with it at all. I also have a 26' camper that I bought last summer that weighs quite a bit more than the pontoon. I'm going to pull it with my '79 Supercab (disc brakes and a 4bbl 460). The most I've towed with my old '70 was 8,100#. Way too much weight! It was a '73 F150 4x4 on a 2,700# trailer. I needed more gear in the rear and much better brakes, but I got the job done safely and slowly. I think a truck used for towing should at least have a class 3 receiver hitch. I just found out that if I have an accident while towing either of my toys with the bumper hitch, my insurance agent won't cover the accident. Time to go buy a good hitch!
Jason Kendrick
1970 F100 Custom 390/C6
1978 F150 Ranger Lariat Supercab 460/C6
Jason Kendrick
I believe 1000 pounds is going to be about it for the F100. Remember that it is less than a true half ton. usually the trucks weight subtracted from the gvwr will give you the capacity. Look on the door sticker for a gross axle weight rating. It should list two different ratings for the front and rear. Like posted above, install a good class three reciever hitch. I highly reccomend Draw-tite, they are a bit pricey, but you get what you pay for. Make sure that whatever you buy has at least surge brakes...and for a camper, electric brakes with a controller in the cab is best. If you aren't sure what to get, any reputable draw-tite (or other brand) dealer will be able to help. I can't stress trailer brakes enough..especially with a vehicle that has barley enough brakes to stop itself. (if you have the cash, front disks are a fantastic upgrade. Good luck
Captain Tim Bland
1986 F150 SWB 4WD
300 I6 1bbl
3.08's
NP205
4speed
Captain Tim Bland
1986 F150 SWB 4WD
300 I6 1bbl
3.08's
NP205
4speed
HouseMouse
Fifth Wheel & Gooseneck RV Towing
12-31-2016 08:59 PM
