New f350 diesel automatic trans chatter
There is a TSB for this issue on the 08's and 09's, TSB 09-4-9 (Shudder or vibration on acceleration - Especially when loaded). The one downside to having the TSB performed is it warns that you may endup with the same shudder or vibration when the vehicle is unloaded instead. Basically the TSB is only worth having done if the truck is experiencing the issue and is driven loaded more often then unloaded...
The TSB only appears to apply to trucks with 156" and 172" wheelbases and is only covered under warranty if you are still within the 3/36 portion of the warranty...
mechelement
07-20-2010 06:36 PM
