How to change rear wheel cylinder? - Ford Truck Enthusiasts Forums
Old 04-03-2009, 11:37 PM
boggerted boggerted is offline
boggerted is starting off with a positive reputation.
I need to change my rear wheel cylinder on my 89 F350 with the 10.25. Now, on my old truck with the D60 rear, I had to pull the whole inner axle apart to change the WC. Is this necessary on these rears? I really hope not, that was such as PITA.
Old 04-04-2009, 01:00 AM
LCAM-01XA LCAM-01XA is offline
LCAM-01XA has a very good reputation on FTE.LCAM-01XA has a very good reputation on FTE.LCAM-01XA has a very good reputation on FTE.
Just pull the drums out, and loosen up the brake pads adjuster screw - tis a bit of shoe-horning to get the new wheel cylinders in place with the pads still in, but tis very doable, that's how I did mine a while back. Also, replace both wheel cylinders at the same time, if one is bad the other ain't in much better shape usually.
Old 04-04-2009, 01:02 AM
Dean88's Avatar
Dean88 Dean88 is offline
Dean88 has a good reputation on FTE.Dean88 has a good reputation on FTE.
If ya want, you can just unbolt the entire hub assembly (its only held onto the axle by 4 bolts) and I'm 97% it will swap right over. I had to do that my 88 when I got it, it has a Dana 70 rear axle, and I'm pretty sure the spare I axle I found was a Sterling 10.25
Old 04-06-2009, 06:39 AM
Opossum Opossum is offline
Opossum is a name known to allOpossum is a name known to allOpossum is a name known to allOpossum is a name known to allOpossum is a name known to allOpossum is a name known to all
Quote:
What? Huh? Whah?
boggerted, it's much easier then the 60 no need to pull apart the axle and hub, the drums will come off without all that.
Old 04-06-2009, 10:34 AM
Dean88's Avatar
Quote:
Originally Posted by Opossum View Post
What? Huh? Whah?
The D60 isn't a full floater? My D70 is a full floater, so to pull the hub I had to pull the axle. I was just letting him know that if he didn't want to go through the trouble of trying pull the back brakes apart and try to swap just a few pieces, its possible to take off the entire brake assembly plate off of the donor axle and bolt it on his D60.
oops, sorry I just realized what the OP was asking, I thought he was trying to swap parts from his 10.25 to his D60
Old 04-06-2009, 10:46 AM
Almost all D60's are full floaters, and all D70s are. Are you saying you swaped brake parts between one of the rare odd ball semi-floater D60s and a D70? The only truck in your sig that might have either of these axles is the 88 and to be honest I'm not sure what a 88 deisel would have, and it doesn't say if it's a dually, but it wouldn't be a D60 it would be either a 10.25 or a D70.
Tell me more about this semi-floater D60, I'm curious?
It did just hit me that the OP might have had a semi-floater D60 in his old truck and was asking about that. He didn't tell us much about the trucks did he?
Old 04-06-2009, 10:57 AM
Dean88's Avatar
Dang it, I hate my of coherency on the internet.
When I bought my 88 diesel (which has a D70 full floater), the entire passenger side brake was destroyed (it hung a shoe I'm guessing, then 7,000 lbs of truck finised off the rest), but a buddy of mine had a Sterling 10.25 laying around, so I just swapped the entire brake assembly off of the Sterling 10.25 to my D70
and you are correct, these diesels pretty much came with either the D70 or the Sterling 10.25, however there are a few odd ***** that have come about. I've heard that a few of the F250's could come with a 8.8 hiding under it, or as you've mentioned the semifloating D60 that came in the light duty F250
Old 04-06-2009, 11:10 AM
It's all good,
I can't remember if the axles have to come out to get the drums off a semi-floater D60, I don't think so but who knows those things are such an abomination anyhting is possible. I would never own one of those axles, and haven't worked on one in many years.
I didn't know D70 and 10.25 brakes swapped, you learn something new every day.
Like the sig, I to support the Libertarian cause. In fact I could use some like minded help here- http://www.ford-trucks.com/forums/83...le-cops-3.html
Old 04-06-2009, 06:43 PM
The D60 under my F250 is a full floating rear, but you cant just pull the crums off them, the hub has to be removed with it. its a PITA
Old 04-06-2009, 11:03 PM
Dean88's Avatar
What do you mean, what else do you have to do besides pull the axle?
Old 04-06-2009, 11:22 PM
With a normal D60 you gotta take apart the hub assembly to work on the brakes. This is because the drum is pressed onto the hub from the back with the lug studs. But it isn't really that hard.
1972 f600 rear wheel cylinders jasmoore Large Truck 4 06-10-2016 08:01 PM
Brakes spongy Olustee Bus 1973 - 1979 F-100 & Larger F-Series Trucks 3 10-18-2015 05:02 PM
1989 f150 brake issues 1990-f250 1987 - 1996 F150 & Larger F-Series Trucks 1 08-25-2015 06:20 PM
Replacing Wheel cylinders Sterling Differential fasthauler Brakes, Steering, Suspension, Tires, & Wheels 1 08-13-2015 12:51 PM
1998 f150 2x4 rear drums locking up Josephdesilva76 Modular V8 (4.6L, 5.4L) 0 03-06-2015 12:01 PM
Tags
1996, 1997, 70, change, changing, cold, cylinder, duty, f150, f250, f350, light, rear, replace, truck, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
