Gauges Installed In Dash, Lots o' Pics! - Ford Truck Enthusiasts Forums
Old 04-03-2009, 11:17 PM
cartmanea cartmanea is offline
cartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to all
Well, I finally settled on the ISSPRO EV2 gauges; pyro, fuel pressure, and boost. I installed the pyro gauge in a single gauge pod under the pillar handle. Fuel pressure and boost went in the dash on either side of the steering column. Below are pics and descriptions. I'm really pleased with how the dash gauges turned out, definitely better than I expected.
First off, I used some mesh cable sleeving to make the wiring harnesses all purdy:
Next I installed the sensors, pyro in the driver side manifold:
Boost in my Banks elbow:
Fuel Pressure in the test port of the fuel filter housing. This actually cracked my housing and it now has JB Weld sealing the leak; GOS has pulled this fitting from their shelves now because of this problem, great service though (Thanks Aden!). I have another housing in the mail. I added a 45 degree fitting to keep the harness away from the upper radiator hose.
Here's the single gauge pod and pyro wiring, more sweet sleeving:
Pyro gauge installed. I liked the non-color-coded gauge, its a bit cleaner looking:
Behind the dash bezel... The right side needed a little Dremel action to make room the the gauge to insert, left side there was plenty of room:
I used a 2" hole saw and drilled from the back with the drill in reverse to make it slower and cleaner:
Finished product. The ISSPRO gauges match great and look almost stock. I am very pleased to say the least.
Big thanks to Aden at GOS Performance for the great deal on the gauges and excellent customer service. Also, thanks to Michael at ISSPRO and CSIPSD (both on The Diesel Garage). Feel free to ask any questions about the gauges or the install!
Old 04-04-2009, 12:06 AM
brickie's Avatar
brickie brickie is offline
brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.
That is a fine job you did there.
Old 04-04-2009, 12:33 AM
gross30's Avatar
gross30 gross30 is offline
gross30 is starting off with a positive reputation.
That does look really sharp, nice work !!
Old 04-04-2009, 12:35 AM
bismic's Avatar
bismic bismic is online now
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
Excellent work there cartmanea. I think it would be appropriate for you to tell folks about your whole journey w/ your truck. It is very impressive - especially with the fact that you are in school AND getting all these things done!
Old 04-04-2009, 02:10 AM
Quote:
Thanks Bismic, by journey are you referring to it being like this when I bought it? Totaled with a bent frame, only way I could afford to get into one.
My grandfather owned a body shop that my dad grew up in, I have to thank him for teaching me how to work on cars. Also a big thanks to all the knowledge I've gotten on the forums It was definitely tough getting it done while in school, especially since I worked on it at home which is 6 hours away. Did all the planning and parts ordering and then did most of the work over 3 weeks of winter break last year, then its been a little here and there for upgrades.
Old 04-04-2009, 07:54 AM
juneau76's Avatar
juneau76 juneau76 is offline
juneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud of
Great job. That was pretty innovative to stick those into the dash panel like that.
Old 04-04-2009, 08:49 AM
D8chumley's Avatar
D8chumley D8chumley is offline
Resident smarta$$
D8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud of
Ditto- very clean looking install. I DO like the way the gauges match.
Old 04-04-2009, 09:08 AM
liv liv is offline
liv is gaining momentum as a positive member of FTE.
Looks very clean. Are they hard to see sitting straight up in the seat with the wheel straight? Also why's you take the steering wheel off?
Old 04-04-2009, 12:43 PM
Quote:
I can see almost the full gauges without interference, loose about 1/4" of the top of the boost gauge with the shifter in Drive. The airbag was out because that is part of the procedure to remove the dash, I had it out at the same time doing sound deadening... that writeup to come soon
Old 04-04-2009, 12:53 PM
Maxium4x4's Avatar
Maxium4x4 Maxium4x4 is online now
Maxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputation
Nice Job on the install, I like the idea of drilling with a hole saw in reverse.
Old 04-04-2009, 01:01 PM
brickie's Avatar
My boost and EGT are in the dash where the 4x4 switch is on some trucks.I had my fuel pressure gauge was mounted where the auto shifter is but the a/m housing squeaked. I took it out and was going to put it where you put your boost gauge is,now I know that it fits, it's going there.
Old 04-04-2009, 01:06 PM
liv liv is offline
Quote:
Seriously? I never take mine off. Guess I won't sit in front of it next time I take it apart
Let us know when you get that sound deadening write up. I am going to be doing that pretty soon too. 2000 watt sound system shakes a lot of thing loose
Old 04-04-2009, 01:11 PM
When you remove the airbag there is a tab on the plug which shorts the pins and prevents static electricity from setting it off. The plug on the dash harness doesn't have this tab though, so that is why it has you remove them. It probably would have been okay to leave them in though. I'll try to get the sound deadening writeup done today.
Old 04-04-2009, 09:09 PM
Sarge261's Avatar
Sarge261 Sarge261 is offline
Sarge261 has a brilliant futureSarge261 has a brilliant futureSarge261 has a brilliant futureSarge261 has a brilliant futureSarge261 has a brilliant futureSarge261 has a brilliant futureSarge261 has a brilliant futureSarge261 has a brilliant futureSarge261 has a brilliant futureSarge261 has a brilliant futureSarge261 has a brilliant future
I know you bought htat truck totaled and you have done a great job with it. Do you know what brand/make those fender flares were. I think that is going to be my next upgrade so I am trying to find something I really like, and the ones in your pic. look like something I would be interested in.
Sarge
Old 04-04-2009, 09:23 PM
Maxium4x4's Avatar
Sarge, Bushwacker has different style flares that you would probably like and probably the best no drill ones offered.
Ford Flares from Bushwacker
Sct tunes for my x3 tuner 6LPSD 6.0L Power Stroke Diesel 17 07-21-2013 11:44 PM
Totaled... Again cartmanea 1999 to 2016 Super Duty 60 02-26-2011 08:02 PM
Blackstone UOA - Mobil 15w-40 with Hot Shot's Secret cartmanea 6.0L Power Stroke Diesel 2 09-30-2009 05:33 PM
Totaled... cartmanea 1999 to 2016 Super Duty 107 08-17-2009 04:02 PM
Rebuild Pics - Finally Got It Done!!! (mostly) cartmanea 1999 to 2016 Super Duty 29 02-10-2008 11:54 AM
Tags
boost, dash, ev2, ford, gauge, gauges, guage, installations, isspro, mount, pod, powerstroke, read, s60r, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
