Towing 5th Wheel w/ 4WD or 2WD - Bed Height problems - Ford Truck Enthusiasts Forums
Old 07-29-2000, 04:16 PM
camper camper is offline
camper is starting off with a positive reputation.
I am thinking of buying a '97 F350 dually extended cab with Powerstroke diesel and automatic. I want to pull a 5th Wheel Camper. I also want to get 4WD since I have been stuck on wet grassy fields before. I don't really know if this is a good idea or not to get 4WD. I am also worried about how high they are with 4WD and if a 5th wheel camper will fit over the bed rails. Would like to hear anybody's experience in needing 4WD for camping or in the bed height issue. I don't plan on using this off-road at all. Only highway & secondary roads plus state park roads to campgrounds.
Old 08-04-2000, 02:57 PM
daywalker daywalker is offline
daywalker is starting off with a positive reputation.
Off the subject but can you get a pre-99' dually with four wheel drive, I thought they were all 4x2's?
Daywalker
92' F-250 4x4 351 4.10 5spd
Old 08-22-2000, 01:36 PM
maveric maveric is offline
maveric is starting off with a positive reputation.
First things first. Most 5th wheel trailers will fit behind a 4wd. They do not (under most all conditions) hit the bed rails. If you are not going to use the trailer off-road, then you should be fine with the 4wd. Just don't go crazy with suspension lifts. I have seen 5th wheel trailers being pulled behind 90's Fords with 4 to 6 inches of lift. They tilted a bit, but if you are careful, they still shouldn't hit.
Second, I believe Ford has been making 4wd dualies since the 80's. Chevy has been since the 70's and Dodge has been since the 80's as well.
Old 09-21-2000, 11:29 AM
mo4x4 mo4x4 is offline
mo4x4 is starting off with a positive reputation.
You could not get the 4x4 dually of Ford untill the 99 superduty (extended cab and crew cab). Only cab and chassis 4x4 dually's in Ford till 99. If you see otherwise they are conversions. Either by the individual or by companies such as Centurion.
The hitch should be adjustable for height. If not you could do it yourself either via trailer or truck hitch. The trailer should not hit the bed or rails 4x2 or 4x4.
Old 11-05-2000, 04:22 PM
rje
Guest
Posts: n/a
According to the complaint column in Trailer LIfe
Mag., there can be a definite bed heigth problem with the new high riding trucks. Not the bed itself, but the bed sides, in dips and cornering
Old 11-11-2000, 03:14 PM
lineman lineman is offline
lineman is starting off with a positive reputation.
There's a pretty easy solution to bed height problems.I simply placed my axles underneath the springs.The only materials required were 4 new spring locators at $2.50 each.Once everything is bolted in place the spring locators should be welded in place.If you don't have a welder you can drive the unit to any shop to have this done.It only takes 5 minutes.I used a small wire feed welder to tack them in place.The whole procedure was easily done with handtools and can be done in about an hour and a half from start to finish.You can then adjust your hitch to the proper height.You now have a level riding 5th Wheel that gives you plenty of siderail clearance.
This does NOT make your trailer look like a lifted 4X4 either.Most people have to ask if my trailer is a bit higher than factory height.
Dave
Old 01-12-2001, 10:37 PM
deleontow deleontow is offline
deleontow is starting off with a positive reputation.
Old 01-31-2001, 04:04 AM
joeiii joeiii is offline
joeiii is starting off with a positive reputation.
I HAVE A 2001-F350-DUELLY-PSD-CREW CAB- 8 FOOT BED-4X4 WITH THE LA WEST PACKAGE ON IT. MY 5TH WHEELS IS 38 FEET LONG AND HEAVY- CARRIES MY 2 HARLEY IN BACK OF 5TH WHEEL. MY HITCH IS A 22K HUSKY- I HAVE NO PROBLEMS WITH BED HEIGHT. THE HITCH CAN ADJUST TO THE HEIGHT YOU NEED. 4X4 HAVE TO LOVE IT ON WET GRASS AND SANDY CAMPSITE. I TRAVEL FROM BOSTON TO KEY WEST FLA. HOPE THIS HELPS
Old 02-13-2001, 07:52 PM
ben towe ben towe is offline
ben towe is starting off with a positive reputation.
mo4x4,I believe you are mistaken about 4WD duallies,but I'm not sure.4WD has very little effect on the rear height of a truck.My friend's 1997 F-350 4x4 with Power Stroke sits at a virtually identical height in the rear as my 1997 F-250 Power Stroke 2WD but his is almost 4 inches higher up front than mine.I would not worry about a 4WD if I were you,we've pulled lots of goosenecks with lifted 4x4s and had no problems.
Old 03-15-2001, 01:10 PM
billsmith
Guest
Posts: n/a
Dexter Axle makes a over/under axle swap kit for doing this job at home. No welding required.
Old 04-10-2001, 02:35 PM
magnus magnus is offline
magnus is starting off with a positive reputation.
I tow a 37' 5th wheel camper with my 79 F250 4x4 with 33" tires.
eventhough the truck is fairly tall, I have not experienced clearance problems. All good fifth wheel hitches are adjustable in height, also some can be slid backwards, which helps in rough terrain and tight turns.
If you didn't build it, its not really yours.
Old 04-16-2001, 11:34 PM
theologian's Avatar
theologian theologian is offline
theologian has a good reputation on FTE.theologian has a good reputation on FTE.theologian has a good reputation on FTE.
I tow a 30 foot 5th wheel camper with my F450 flatbed, and needed to reverse the axles on the suspension of the trailer to get a level tow, and have gone over 20,000 miles that way, with no problems of stability or wandering, and the suspension is doing fine, as are the axles.
About pre '99 duallies. I have a Ford custom built F450, Crew cab, 4X4 Dually, that I specifically ordered from FoMoCo in 1996. They took 6 weeks to build it, with a 7k front axle, and a 10k rear.
Old 04-17-2001, 11:19 PM
wow sounds like a nice truck theologian
Camper Package and Snow Plow prep package cecilt 2017 Super Duty 15 12-28-2016 08:37 AM
Front leaf spring questions Crewcab Turbo 1999 - 2003 7.3L Power Stroke Diesel 7 11-04-2016 07:19 AM
Help me spend $30,000 on my first 1-ton. Five basic questions: 350duallyTruckCamper 1999 to 2016 Super Duty 27 01-19-2016 12:50 PM
4.6 Liter - How much can I tow? leroys4wd 1997 - 2003 F150 14 02-01-2005 04:20 PM
F350 Crew Cab SRW Long BED 5th Wheel Towing gus57 Fifth Wheel & Gooseneck RV Towing 9 09-06-2003 10:22 PM
Tags
2wd, 4wd, 5th, bed, beds, chevy, custom, f350, ford, height, lifted, riding, rough, tow, towing, trailer, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
