Proportioning valve
on
with mine down all the time i have never had a problem stopping.even with my camper in the back of the truck pulling a loaded 18 foot cargo trailer.they don't lock up and she stops on a dime.plus you don't want the rear end locking up all the time,,hard on tires plus when your tires are locked up and skidding your braking is reduced, plus your out of control on wet pavement the **** end swinging around when the brakes are applied.
on
I agree, Lockup is not a good thing! But reducing loaded braking is far worse!
My rear tires don't lockup except when it's slippery (Snow and Ice) and the truck is empty!
I added ~400lbs in the bed and I no longer have that!
They do not lockup on wet or sandy roads even empty.
If your Height Sensing Proportioning Valve is in the down position, it is your front (and or trailer) brakes doing most of the work.
My bet is your Height Sensing Proportioning Valve is already failed anyways.
-Enjoy
fh : )_~
-Enjoy
fh : )_~
i don't want to high jack this fourm.that leaver is the proportioning valve, when there is a load on the truck the leaver go's up,allowing more brake pressure to the rear brakes. those lift blocks are not factory.if you look closely those round parts are axle tubes.a previous owner cut a rear end up. cut the spring perches off and cut the tube in half.i can see this plain as day.ford would have not left rough cutting tourch cuts on something they produced.
If this is a 4wd truck, those blocks could be factory. Like the other poster said, it looks like the arm has been cut off. That arm is supposed to stick out so a rubber bump stop can hit it. The rubber bumpstop is mounted on the bottom of the frame above this area.
The 4wd trucks did have blocks from the factory.
