Fog lights
I've seen where the switch has been modified to bring on the low beams when using the high beams by modifying it internally. I'm not certain if it would work for the fogs like that with it in parking light mode. What you can do is pick up a 30 amp relay and holder/harness and wire the fogs to be on with the headlights off. I use the parking light on hot wire not the turn signal hot to energize the relays so they are on all the time. The relays get their power directly from the battery so they are brighter than normal. I was changing my stock 02 F-150 head lights out for a european style. The head lights also have relays powering them and they are bright.
fog lights mod
Found the answer on F150 online. Remove light switch from dash with small screw driver. Using 3m jumper connector. Connect the (white/black) wire to the (brown) wire. You also have to modify the light switch. There is a arm attached to light switch stem. Turn light switch to parking lights the arm will hit the guide and not let switch pull out. Take a small file to guide and file down guide enough to pull switch out as far as the light switch does in the head light position. Then mod should work. It takes longer to write mod than do mod.
2002 F150 FX4
Superchips powergrammer
BBK Headers
True duel exhaust
16X10 AE wheels
285X75X16 bridgestone revo tires
2002 F150 FX4
BBK Headers
True duel exhaust
16X10 AE wheels
boblewis
03-02-2012 07:58 PM
BearFootCustom
11-01-2009 06:55 PM
