Superduty won't start - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 04-03-2009, 11:46 AM
nosagroy nosagroy is offline
nosagroy is starting off with a positive reputation.
I have a 99 F-250 superduty w/7.3 L Diesel. Without anywarning of a start problem I tried to start last might with no response, not even so much as a click from a relay. i have checked the batteries and they are both good. There is no corrosion on the terminal posts. I have looked at the cables and there looks like there could be a little corrosion on the inside of the positive cable near the primary battery. Can anyone help me figure out what could be worng (starter? cables? something else?)?
Old 04-03-2009, 11:48 AM
brickie's Avatar
brickie brickie is offline
brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.
Check fuses,then grounds.
Old 04-03-2009, 11:51 AM
Forgot to mention that part. I have looked at the grounds and the fuses. All seems to be good.
Old 04-03-2009, 11:33 PM
QwkTrip's Avatar
QwkTrip QwkTrip is offline
QwkTrip is a splendid one to beholdQwkTrip is a splendid one to beholdQwkTrip is a splendid one to beholdQwkTrip is a splendid one to beholdQwkTrip is a splendid one to beholdQwkTrip is a splendid one to behold
Starter has 2 circuits. One circuit is the starter control for crank and terminate commands. The other is the high power cranking circuit that does the work during engine startup.
There should be voltage at the large battery cable to the starter all the time (same as battery voltage). If not, then you are not getting power to the starter high power cranking circuit.
With the key switch in the start position, check for roughly 12V volts at the starter solenoid switch terminal. If not, then the problem is somewhere in the control circuit and not the starter.
If those pass then replace the starter or have it repaired.
Old 04-03-2009, 11:38 PM
Futuresweets-10's Avatar
Futuresweets-10 Futuresweets-10 is offline
Futuresweets-10 is gaining momentum as a positive member of FTE.
Radio, dash lights, gauges, etc. coming on or no?
Old 04-03-2009, 11:53 PM
F350-6's Avatar
F350-6 F350-6 is online now
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Auto or manual? Have you tried starting in neutral instead of park?
Old 04-04-2009, 02:39 AM
Thanks for all of your replys/suggestions. So here is the update. everything checks out and I tried to start in Neutral with success. When I turned off I tried again in Park and it started again. A few moments later I tried again in Park and it would do anythin again. I think there is a shift lock that prevent the truck from starting when not in Neutral of Park. I am assuming that this is what is the problem. Does anyone know how to fix this?
Old 04-04-2009, 09:29 AM
F350-6's Avatar
Look up under the dash where the lever connects and there should be a couple of torx head screws. See if they've come loose. Sometimes tightening them down will fix this issue. Otherwise it seems like there's an adjustment somewhere on the linkage to check.
Old 09-08-2009, 09:54 PM
clembrey08 clembrey08 is offline
clembrey08 is starting off with a positive reputation.
i have a 99 thats doin the same thing, intermitently wont start in park but if i crank it down to 2nd or 1st then shove it back up to park itll turn over no problem also sometimes when i put it in park like if im parking at a store or something the mechanism that keeps the vehicle from rolling back too far doesn't engage and i'll start rolling back but the motor idles as if it is in park, go figure i guess got to adjust something. oh yeah and it wont drop into first anymore, somethings gotta be wore out, idk.
97 F250 Diesel Battery Cable Corrosion chaines 1999 to 2016 Super Duty 0 08-06-2014 08:51 PM
Weird Battery Cable Corrosion ? DSMMH 6.0L Power Stroke Diesel 14 02-16-2012 04:28 PM
Help with new battery cables please slenser Excursion - King of SUVs 4 12-26-2010 12:32 AM
battery terminal connector replacement handyandy123 6.0L Power Stroke Diesel 3 08-27-2010 05:44 PM
Lead (Pb) battery connectors going bad? Fishin76 1999 to 2016 Super Duty 7 08-12-2010 09:23 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
