Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Western Region > Oregon Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Oregon Chapter Join Chapter, Leader: Fabmandelux
  #1 (permalink)
Old 04-02-2009, 06:42 PM
MikeyLikesIt's Avatar
MikeyLikesIt MikeyLikesIt is offline
Garage is empty, add now
MikeyLikesIt is starting off with a positive reputation.
cam prelube methods. TO SMERE OR TO RUB? whats the best prelube jelly.
what is the best methdod?Click the image to open in full size.
__________________
http://www.ford-trucks.com/forums/pi...523451&thumb=11976 hi-boy 468 Cubic IN. Factory paint. No lift.
  #2 (permalink)
Old 04-02-2009, 06:50 PM
fabmandelux's Avatar
fabmandelux fabmandelux is online now
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
I usually just fill my hand with it, and make sure that every lobe is covered, then coat all the lifters also.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #3 (permalink)
Old 04-02-2009, 06:53 PM
any brand better then the other?
__________________
  #4 (permalink)
Old 04-02-2009, 06:57 PM
1935 Ford pickup
I use a product called Lubriplate Engine Assembly Lube, and have used it for 30 years or more. Never had a problem.
__________________
  #5 (permalink)
Old 04-02-2009, 07:04 PM
does napa carry it?
__________________
  #6 (permalink)
Old 04-02-2009, 07:18 PM
1935 Ford pickup
I don't know if NAPA sells it, but here is what I use:
Lubriplate
__________________
  #7 (permalink)
Old 04-02-2009, 07:38 PM
wmjoe1953's Avatar
wmjoe1953 wmjoe1953 is offline
wmjoe1953 is gaining momentum as a positive member of FTE.wmjoe1953 is gaining momentum as a positive member of FTE.
Use the lube that comes with the cam. Use the lifters the cam manufacturer recommends. That way, if there is a problem, and oyu followed all the steps to the letter, it's on them, and not you. It's a comp cam right? It's comes with a lube, and just put it on the lobes and the gear and smear it around. Put it on the bottoms of the lifters too.
  #8 (permalink)
Old 04-02-2009, 07:48 PM
ok that makes sense. since i took apart the motor should i do any thing to the crank and cyl. at assembly or should they be ok when i prime the oil pump.or after i mean
__________________
  #9 (permalink)
Old 04-02-2009, 07:57 PM
wmjoe1953's Avatar
Did you pull the crank and rods and such out? If not, then you don't really need to do anything but prime the oil system, so that you know you have good clean oil in the system before start up.
  #10 (permalink)
Old 04-02-2009, 08:05 PM
ok, my plan is to run quakerstate 10-40 with zddp for cam break in the flush and change filter. sound good??
__________________
  #11 (permalink)
Old 04-02-2009, 08:06 PM
Milwaukee1979F150's Avatar
Milwaukee1979F150 Milwaukee1979F150 is offline
Milwaukee1979F150 is gaining momentum as a positive member of FTE.
use shell diesel oil 15w40 that what I would do since it have lot zinc
__________________
Sorry for my bad grammar.
Currently drive 2000 f350 7.3L XL 4wd auto. mpg vary 15-17.
1999 F250 5.4L 2wd 5.4L auto with over 246K miles. Got used 5.4L with 100K miles. Need find motivation to install 5.4L.
  #12 (permalink)
Old 04-02-2009, 08:34 PM
joe what do you think?
__________________
  #13 (permalink)
Old 04-02-2009, 08:40 PM
what do you think joe?
__________________
  #14 (permalink)
Old 04-02-2009, 08:58 PM
wmjoe1953's Avatar
any of the quality fleet oils are good...shell, rotella, delo 400. Our engine parts supplier, and engine long block supplier will not honor the warranty if delo or it's equivelant is not used during break in.
  #15 (permalink)
Old 04-02-2009, 09:04 PM
so should i take back the quakerstate and try to get delo or rotella. which one would you use if it was you?
__________________
Tags
cam, camshaft, lube, pre, prelube
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
