Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1987 - 1996 F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 04-02-2009, 05:23 PM
Desert Rider Desert Rider is offline
Desert Rider is starting off with a positive reputation.
E4OD to 5 Speed Manual swap?
I believe my E4OD on my '93 7.5L F350 finally gave it's last breath.
Haven't started diagnosing it yet, but after spending a couple of hours researching countless threads describing E4OD failures, I think mine is toast.
I'll prolly spend some time this weekend doing a few things to determine it's state, but my outlook is pretty grim, kinda like my checking account is right about now.
I know someone with an '89 7.3L diesel F350 with a manual 5 sp tranny. They're looking to get rid of it really cheap.
Will the tranny off the diesel mount up to my 7.5L?
Will I also have to switch over the wiring harness, computer, and all the associated sensors?
I'm sure there are several issues regarding differences between the 7.3D and 7.5FI that I'll have to deal with as well.
Is it worth the headache?
Thanks in advance for any input.
  #2 (permalink)
Old 04-02-2009, 08:19 PM
LynnL's Avatar
LynnL LynnL is offline
LynnL is starting off with a positive reputation.
I know it would be better if you had the donor truck available, that way if you needed a specific nut, bolt or bracket, you'd have it right there.
I'm not 100% on the bolt pattern match, but I believe they're the same.
I don't think the computer would be an issue, possibly a connector may have to be swapped.
The driveshaft may have to be swapped, also.
I thought about the same thing when my tranny died, but wound up spending the money for a built E40D. 2 weeks later, a truck came through the salvage yard with everything I needed. When I checked it out, It looked pretty straight forward.
  #3 (permalink)
Old 04-02-2009, 08:42 PM
Ford4x4-JD70AB's Avatar
Ford4x4-JD70AB Ford4x4-JD70AB is offline
Ford4x4-JD70AB is starting off with a positive reputation.
There will be quite a few small parts to switch over, so a donor truck would be better. I think the 7.5L and the diesel have two different bell housings, maybe someone else knows. Ive gone from 4r70w to the m5r2 five speed so its not too difficult.
__________________
1995 Ford F-150
Black/Silver-Extended Cab-4x4-M5R2
Powered by a 3.9L Cummins 4BT TurboDiesel
  #4 (permalink)
Old 04-03-2009, 08:27 AM
alxsnmr alxsnmr is offline
1991 Ford Bronco
alxsnmr is gaining momentum as a positive member of FTE.
From my thread searching and reading, the diesel and 460 don't share the same bell housing pattern. It would be better to search for a 460 5spd or a whole truck that is similar in cab and bed to yours with a 460 and 5spd.
__________________
Stock 1978 F250 Custom regular cab 4x4 with 351M and 4 spd.
1991 Bronco silver anniversary, 5.8L EFI, E4OD swapped for C-6, custom trimmed rear fenders finished in rust.
2009 Fusion SE 2.3L 5spd Red/black cloth n leather
  #5 (permalink)
Old 04-03-2009, 08:44 AM
Lazy K Lazy K is offline
Lazy K is gaining momentum as a positive member of FTE. Lazy K is gaining momentum as a positive member of FTE.
Quote:
Correct. You need one from a gas big block not a diesel.
  #6 (permalink)
Old 04-03-2009, 09:29 AM
jas88's Avatar
jas88 jas88 is offline
jas88 is gaining momentum as a positive member of FTE.
Here is everything you need to do the swap (this is for a 4x4 but you get the idea):
I found that pic useful when I did my swap.
__________________
1991 F150 SuperCab 4.9L/ZF5
1991 Bronco SAE 5.0L/E4OD
2005 Escape 2.3L/CD4E
  #7 (permalink)
Old 04-03-2009, 12:15 PM
andym's Avatar
andym andym is online now
1989 Ford F-150
andym has a spectacular reputation. andym has a spectacular reputation. andym has a spectacular reputation. andym has a spectacular reputation. andym has a spectacular reputation. andym has a spectacular reputation. andym has a spectacular reputation. andym has a spectacular reputation. andym has a spectacular reputation. andym has a spectacular reputation. andym has a spectacular reputation.
Where do the clorox and the lawnmower come in?
Yes, they are different bellhousing patterns, and different gear ratios anyway. Even if you could do it, you wouldn't want to use a diesel 5 speed behind a gas motor.
__________________
Andy
Quote:
You can't change the wind, but you can adjust your sails
Facebook
  #8 (permalink)
Old 04-03-2009, 12:18 PM
1991 Ford Bronco
Quote:
The lawn mower is to cut the grass away from the truck so you can get to it. The Clorox is for later when you light the tires up on the pavement.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
