1997 f150 vs 2000 f150 compatibility ?
Hi,
I found a deal on front seats from a 2000 f150 reg cab, 60/40 split with center console. My question is, Will they fit in my 1997 f150 reg cab using the same bolt holes ? I prefer the seats from the 2000 because they can recline and have a center console which flips up and acts as a third seat when needed.. Much better design then my 97's straight non adjusting bench seat..
Thanks in advance,
Kyle
Thanks in advance,
Kyle
This should work out for you with minor adjustments. Be sure to get all of the attaching brackets and bolts from the donor vehicle. Some of the mounts for the seats may be a little different than what is coming out. You should find that the floor pan has untapped holes for any that are different and that the bolts are all self tapping. Run the bolts in to mount it up! Good luck!
