7.3 liter stock turbo
I believe the 7.3 engine from 1989 would have been the 7.3 IDI engine which would mean that I don't believe you could add it in.
You could certainly post your question over in the https://www.ford-trucks.com/forums/forum117/ channel which covers all years that the 7.3 IDI motor was standard in.
Sadly he hasn't been very active in the last 10-15 years! Super guy! Message him and he may respond!
On a naturally aspirated diesel, the only purpose of the intake manifold or its gasket is to keep dust out of the engine. Unlike a gas engine, there is no significant pressure differential between both sides of the gasket. Furthermore, even if the gasket did leak, it wouldn't matter like it does on a gas engine where the vacuum level is critical to proper combustion and fuel mixture. So yeah, long story short, as long as it's in good enough shape to keep bugs and mud out of the engine, you can reuse it.
Wellcraft
08-31-2004 08:38 AM
jetdoc1971
01-04-2004 10:23 PM
