You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I've got a 93' ford f-150 5.8L 1/2 ton 4X4 engine code H. When I lightly press the gas pedal the engine idle lopes. If i press the pedal further the problem goes away or if i let off the pedal the problem goes away. This does not happen if the egr valve is disconnected. I'v replaced the egr valve, the egr vacuum solenoid, and the egr position sensor and none of them leak. What are some probable causes for this. Also the thermactor air system is inoperative during self check test.
Does your truck have a throttle position sensor? on my 98 F150, mine did the same thing. Replaced the sensor and truck ran like a champ.
__________________
Fierce Off Road Destroyer - 08 Ford F350 FX4 Crew Cab Black on Black w/ 8" Lift, 38x13.5x20" Nittos on XD wheels. Uniden CB, Wilson 1000 and a PA. Air horns w/ compressor and tank.
Fierce Off Road Destroyer - 73 Ford Bronco Roadster. 302 w/ "mods", C4, D20, D44, 9", 6 Point Cage, Rancho Lift, 35x12.5x15" Mud Tires on Aluminum Rims
Eddie, you beat me to the punch on this one. I am willing to bet that it is the TPS that is bad.
__________________ Neil aka Tiny aka Hugo...... Official #2 Slackmaster & Pyroslacker Extraordinaire
2001 F150 XLT Supercab 4x4 & 2008 Edge SEL AWD To Join The NEW YORK CHAPTER CLICK HERE RIP Phil, phil6608.... you will be sadly missed my friend
Yeah my truck does have a throttle position sensor on it, but while I was searching for a thermactor air bypass valve at a junk yard, I saw some engines with original vacuum lines still connected. I noticed I had the vacuum lines at the egr vacuum solenoid criss crossed. I put them were their supposed to go and problem fixed.
__________________
I put the air bypass valve I got from the junk yard (of course I vacuum checked it before I took it off the engine) in and system works. I scanned the computer and I got code 111 NO DEFAULTS DETECTED!!! Yeah
