Generic Electronic Module (GEM) - Page 4 - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #46
Old 12-10-2012, 04:03 PM
Pitcrw6's Avatar
Pitcrw6 Pitcrw6 is offline
Pitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant future
I think the VSM ties into the pedal assy some how but im not to sure. I have a diagram on my computer but right now im on my phone. Maybe someone can post it up. I wish you can attach pics on the mobile version of FTE. Sure would be nice.
  #47
Old 12-11-2012, 01:59 AM
Nsaan's Avatar
Nsaan Nsaan is offline
Nsaan has a great reputation on FTE.Nsaan has a great reputation on FTE.Nsaan has a great reputation on FTE.Nsaan has a great reputation on FTE.Nsaan has a great reputation on FTE.
Quote:
Originally Posted by Engalwood View Post
Then some times I have to hit the center temp reader on the roof of the cab to get it to come on. Its right above the rear view mirror.
This is a separate issue, more then likely it is a resistor that come unsoldered from the display board.
http://www.ford-trucks.com/forums/44...-gone-out.html
  #48
Old 12-11-2012, 08:45 AM
Engalwood Engalwood is offline
Engalwood is starting off with a positive reputation.
SO no one has any mo effn flippn dang on idea what would be causing my Acc Pedal to do what its doing?
  #49
Old 05-31-2014, 02:39 PM
bigtexan99 bigtexan99 is offline
bigtexan99 is gaining momentum as a positive member of FTE.bigtexan99 is gaining momentum as a positive member of FTE.
I've developed a battery drain on my early 99. The alternator is not warm in the morning, so I don't think its the cause. Disconnected auxillary lines I have connected to the battery and the trailer wiring at the rear bumper....battery still partially drains overnight.
Thinking it might be the GEM, although I don't have any of the erratic symptoms others have seen with a faulty GEM.
Is there a fuse I can pull that will kill power to the GEM or do I have to remove it as per the instructions at the beginning of this post? Would like to leave it disconnected overnight and see if there is any drain.
  #50
Old 12-14-2014, 10:06 PM
cowboy_up_07's Avatar
cowboy_up_07 cowboy_up_07 is offline
cowboy_up_07 is starting off with a positive reputation.
01 F350 7.3l dually needs an exorcist!
Hello every one. I have a 01 F350 dually 4x4 automatic tranny with a 7.3L And the problem I am having is only when it raining. The day time running lights stay on unless I pull the fuse, and the horn will just start blowing but stops when you open the door and starts again when it's closed, the blower motor keeps running unless turned off, all of this when the truck is off and the keys out of the ignition. Also the speedometer works off and on when driving. There is a clicking noise coming from under the dash on the right hand side behind the ashtray area that was not there before when cranking the motor.
The truck now is having starting issues also in the cold weather even if it's plugged in it will crank over fine. But no start if you are cranking it for like 15 seconds each time on the third attempt the batteries dies. Then some times when I turn the key there is nothing no click From the starter or the solenoid but if you turn the key of and on a few times it will crank.
I have looked at everything I can think of as far as fuses but have not found anything. This is only when it's raining other than that the runs great when it's not wet outside. I have not seen any or noticed any dampness under the dash.
I am at my wits end any help I can get will be greatly appreciated thank you
  #51
Old 12-14-2014, 10:20 PM
Quote:
Originally Posted by SUPERDUTY OUTLAW View Post
I cut and tried splicing then used a harness so yes and true
should never cut the stereo harness on a ford , it messes them up. I have done it a couple times before when I was a kid. So when I turned on the headlights with out the key in the truck the stereo would come on. Even when I wired the original plugs back on and used a installation kit the problem was still there even with the factory radio back in.
So always buy an install kit if changing stereo.
  #52
Old 12-14-2014, 10:30 PM
InOverMyHead InOverMyHead is offline
InOverMyHead is starting off with a positive reputation.
There are 3 relays about where the ashtray is, left of the stereo-right of the steering column- above the floor heater duct, hazard flashers or something like that. There's also a good chance the GEM has been compromised. I had some electrical issues and found it was a combination of the two.
  #53
Old 12-15-2014, 12:27 AM
ztodd377's Avatar
ztodd377 ztodd377 is offline
of FTE, RHN, and BEER!
ztodd377 is gaining momentum as a positive member of FTE.ztodd377 is gaining momentum as a positive member of FTE.
I had almost identical issues, minus the starting issue, searched everywhere, couldn't find a leak but I bought some high temp silicone and sealed every hole I could find on the drivers side firewall as well as ran a bead around the lower part of the windshield and the problem went away.
  #54
Old 12-15-2014, 12:42 AM
Testing the Gem
Is there anyway to test the Gem module with out pulling it. cleaning it up drying it out per say like was mentioned earlier in this thread?
  #55
Old 12-15-2014, 03:43 AM
ztodd377's Avatar
Not sure about testing it but I did have mine out a couple of times, which is a chore itself, and visually checked for anything wrong as well as letting the connectors all have time to dry out.
Replacing GEM on 2003 F250 madjak 1999 to 2016 Super Duty 6 05-03-2016 06:54 PM
Battery keeps dying. Mustangguy302 Expedition & Navigator 6 11-24-2014 11:35 PM
GEM Computer Problem Banjoono Explorer, Sport Trac, Mountaineer & Aviator 2 06-05-2014 09:58 PM
Is there a way to kill power to the GEM bigtexan99 1999 - 2003 7.3L Power Stroke Diesel 3 06-02-2014 07:09 PM
EX 4X4 not working...And a snpwstorm in WI... hogrydr Excursion - King of SUVs 2 12-09-2012 07:42 PM
Tags
2002, 99, codes, duty, electronic, f250, f350, ford, gem, generic, module, powerstroke, price, super, wiper
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
