Generic Electronic Module (GEM) - Page 2 - Ford Truck Enthusiasts Forums
Old 04-03-2009, 12:56 PM
SUPERDUTY OUTLAW's Avatar
SUPERDUTY OUTLAW SUPERDUTY OUTLAW is offline
SUPERDUTY OUTLAW is gaining momentum as a positive member of FTE.SUPERDUTY OUTLAW is gaining momentum as a positive member of FTE.
I cut and tried splicing then used a harness so yes and true
Old 04-03-2009, 01:03 PM
megawatt00's Avatar
megawatt00 megawatt00 is offline
megawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputation
Double and triple check all of your connections there. Some of the radio functions may go through the GEM. Did you ty the radio before the harness went in?
Old 04-03-2009, 02:03 PM
No I didn't try it before the harness went in. I am pretty good at everything on my truck except wiring. I have wired my trailer 3 times now cause I was doing it backwards lol.
Old 12-30-2009, 04:25 PM
appytaxi appytaxi is offline
appytaxi is starting off with a positive reputation.
OK - Jock D, you were a great help in getting the GEM out. Now that it is out and I have no obvious signs of corrosion or 'badness' what should I do? It appears that based on all the truck issues I have that my GEM is going bad - I would have bet money on corroded connectors because of the off and on nature and the wide variety of problems.
Do I just replace it now?
Old 01-06-2010, 11:09 PM
silent209 silent209 is offline
silent209 is starting off with a positive reputation.
Hello, i have a question, if i was to change my GEM and put on a used one from the same year, will it still work or do I need a new one and have the dealer program it.
Old 01-07-2010, 12:12 AM
JockD's Avatar
JockD JockD is offline
JockD has a very good reputation on FTE.JockD has a very good reputation on FTE.JockD has a very good reputation on FTE.JockD has a very good reputation on FTE.
I am not a GEM expert, but in troubleshooting one on my 2001 I tried another GEM from a similar truck that had more options and it did not work well at all. It makes me think that the combination of options and programming are very specific to the way the truck is optioned, but is not unique to only one truck. Based on that, I would not try to replace a GEM with a used one unless it was for the same year truck with exactly the same options (at least those controlled by the GEM).
The safe thing to do would be buy a new one and have the dealer (or someone with a tool that can program the GEM) set it up for the few field-programmable options. I think tire size and something else.
Appytaxi, I was not following this thread, but my suggestion would be to check out the sensors and wiring that control the GEM function that is giving you trouble before you invest in an expensive new GEM. Try to eliminate the less expensive stuff as the problem!
Old 01-07-2010, 12:33 AM
Riffraff Performance's Avatar
Riffraff Performance Riffraff Performance is online now
PREMIUM SPONSOR
Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.
Anytime you swap another GEM in you will need it to be programmed to your truck. You don't need to have a new one though. The dealer tried to tell me the same thing and that they couldn't program a used one to my truck. I had to find a tech who knew what he was doing to finally get it fixed.
I am actually running a 2001 PCM, and 2000 GEM in my Early 99'
Old 01-07-2010, 04:54 AM
ltl_jrw's Avatar
ltl_jrw ltl_jrw is offline
ltl_jrw is starting off with a positive reputation.
I bought a new GEN off E-Bay for $175.00 and it works perfect. I sent the guy the numbers off my old one and he programed mine and I have not had a problem in a year.
Mine was getting wet due to my stupid cab lights. Got lights fixed and no more problems.
Old 01-07-2010, 12:44 PM
hrod79's Avatar
hrod79 hrod79 is offline
hrod79 is starting off with a positive reputation.
Do you have any contact info for the guy on E-Bay?
Old 01-07-2010, 06:28 PM
ltl_jrw's Avatar
Quote:
Sorry, I don't have his comtact, it was back in Febuary.
Old 01-07-2010, 08:16 PM
ztodd377's Avatar
ztodd377 ztodd377 is offline
of FTE, RHN, and BEER!
ztodd377 is gaining momentum as a positive member of FTE.ztodd377 is gaining momentum as a positive member of FTE.
Mine was acting funny in the fall because water was leaking in somewhere and getting to the GEM somehow. I had the windshield pressure tested and it tested good, so I took some black epoxy and sealed every hole in the firewall on the driver side. No more problems since.
Old 01-12-2010, 08:51 PM
Thanks Guys,
I did see a tiny itty bitty bit of corrosion on the GEM so I got it cleaned up and put back together (that was fun) and the truck started up great. 3 days later it wouldnt start again. there is no sign of water or dampness in the Gem - it looks perfect. Now we are going back to the car alarm because there seems to be a correlation there too - like the kill switch is malfunctioning.
BTW some GEMs are plug and play - the E version for this truck is and that is what I have.
If Car Toys finds that it isnt the alarm then I guess it is back to wires and electrical stuff (which just confuses the heck outta me)
  #28
Old 06-11-2010, 01:06 AM
vwmike72 vwmike72 is offline
vwmike72 is starting off with a positive reputation.
I bought one off of ebay and it didn't do anything to help problem. Maybe bad GEM? Getting my money back though and will try again!
  #29
Old 06-11-2010, 03:27 PM
gtnwood's Avatar
gtnwood gtnwood is offline
gtnwood is starting off with a positive reputation.
Quote:
Exacto mundo same here, but had to replace the fuse panel at the same time, works like new again
  #30
Old 06-11-2010, 07:56 PM
crum71's Avatar
crum71 crum71 is offline
1/8 mile Oval Track
crum71 has a great reputation on FTE.crum71 has a great reputation on FTE.crum71 has a great reputation on FTE.crum71 has a great reputation on FTE.
I had to buy one in December, got it from a place in Florida for 150.00 all the numbers matched. It has worked perfect and didn't have to get it programmed. Took an hour to get it out,but maybe 15 minutes to put back in.
Gem module Wrecking ball 1999 - 2003 7.3L Power Stroke Diesel 11 06-27-2016 06:52 PM
Battery keeps dying. Mustangguy302 1997-2006 Expedition & Navigator 6 11-24-2014 10:35 PM
Is there a way to kill power to the GEM bigtexan99 1999 - 2003 7.3L Power Stroke Diesel 3 06-02-2014 06:09 PM
no map lamps, power windows, radio pooch Electrical Systems/Wiring 5 05-17-2009 08:25 PM
Where is the GEM? xtra1es 1997-2006 Expedition & Navigator 4 12-15-2002 10:57 AM
Tags
2002, 99, codes, duty, electronic, f250, f350, ford, gem, generic, module, powerstroke, price, super, wiper
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
