1982 Ford Carb Photo Questions
1982 Ford 300 Inline 6, Motorcraft Carb # 7640, 4WD, F250
Its been running great, but occasionally after I start it I have to get out and push the choke plate open once to get it off choke. I went to fix it and I found a few lines with screws in them and some unhooked lines. My Chilton doesn't give hardly any information on line routing for this setup.
1) Is there a place with more information about this specific setup and where the lines should run?
2) Where is this carburetor line with a screw in it supposed to go, and what does it do?
3) Where is this engine line with a screw in it supposed to go, and what does it do?
4) Where is this orange engine line supposed to go, and what does it do?
5) Where is this carburetor wire supposed to go, and what does it do? It didn't run to anything when I took it off the truck.
6) How do I set this choke? (the three screws that set the choke richness by turning it where loose when I took it off the truck)
7) Where does this threaded connection at the side of the choke assembly go to? Nothing was hooked up to it on my truck when I took it off (not my carb, but the same one off ebay)
8) Is there a routing diagram for the choke arm that is attached to the choke assembly by a bent wire? It appears that mine jambs and holds the choke from opening / closing.
Thanks guys, I appreciate the help.
It think I found a page that has some stuff on it. It appears someone basically unhooked the choke to the carb.
Carter Y, YF, YFA, YH, YS - The Carburetor Doctor
on
You can get this tube and fittings in the help section of most auto part stores. Universal Choke Stove Tube Repair kit.
on
Here is a diagram for the Carter YFA.
It's for a feedback carb, so parts on your carb will vary because you have a Carter YF.
But it will give you an Idea.
https://www.ford-trucks.com/user_gal...oid=97997&.jpg
The carb kit you buy will have a simular diagram for your application.
SkySkiJason
20
12-24-2012 08:22 AM
ctubutis
'80-'86 FAQs (Frequently Asked Questions)
03-30-2011 08:20 PM
79F-1504x4
17
06-05-2010 11:02 PM
gryffinwings
09-28-2009 03:50 PM
100, 1980, 1982, 1986, adjustment, carbs, carburator, carburetor, chilton, f100, f150, ford, picture, saint, truck
