1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Intermittent starter motor failure to turn over
Old 04-01-2009, 08:04 PM
fred_79f250's Avatar
fred_79f250
fred_79f250 is offline
Gentlemen,
2000 XP, 5.4l, auto.
A couple motnhs ago when it was real real cold the starter motor wouldn't turn over in the morning. Just 'click'. But if I re-tried the key a few times eventually it would turn over. Once it warmed up it would turn over first try the rest of the day.
At first I thought it was dying. But then the weather warmed up and it stopped doing that. Just started just fine every morning. So I thought maybe something to do with th ecold - some water got in and froze????
BUT - this week - we're above freezing - and the problem is back. Exact same behaviour.
Intersting detail - the time I turn the key that it does turn over, often the door locks flip as if I'd hit the lock/unlock button.
I'd simply replace the starter motor, but before I do that I'm curous if this sounds like anything else anyone recognizes.
Thanks.
Old 04-01-2009, 09:00 PM
alloro's Avatar
alloro
alloro is offline
Received 4,194 Likes on 2,430 Posts
A bad battery will do this too.
Old 04-03-2009, 10:16 AM
fred_79f250
A bad battery? Can you explain a little more?
Thanks.
Old 04-03-2009, 12:18 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Parts Guy Wyatt is offline
Former Vendor
If your truck still has the original battery in it you may be experiencing a dying battery that is ready to be replaced. Dan.
Old 04-03-2009, 12:57 PM
Omahastro1's Avatar
Omahastro1
Omahastro1 is offline
Whe the starter doesn't turn over crawl under the truck, tap the starter with a hammer don't wack it hard, then see f the starter works. If it does it is the starter. Also look at your starter connections I know mine look bad. If they are coroded this will cause this same problem.
Old 04-03-2009, 05:15 PM
Modified 99's Avatar
Modified 99
Modified 99 is offline
Could have been the battery terminals needed cleaning. ;-)
Old 04-03-2009, 08:48 PM
fred_79f250
Ya, OK - go back to basics. On my 79 F250 I'd go straight to corroded connections or battery posts. But the XP's got a 2-year old Optima gel-cell battery in it, new (reman) starter last fall, and a brand new OEM Ford starter wiring harness - so I hadn't thought about any of that possibly being faulty. But I'll go over it.
Old 04-07-2009, 06:07 AM
Gevans17's Avatar
Gevans17
Gevans17 is offline
My 98' Expy was doing that a few months ago. Intermittent no crank, just a click at the relay when I turned the key. I cleaned all electrical connections at battery, firewall, ground., starter..has not happened again.
BrittsNFords
15
04-13-2016 10:47 AM
fightlivefree
05-17-2015 04:58 PM
Jeffro95
02-27-2014 05:59 AM
Snafu_Bohica
12-07-2012 07:58 PM
seaweaver
1999 to 2016 Super Duty
10-13-2012 10:16 AM
Quick Reply: Intermittent starter motor failure to turn over
