Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 04-01-2009, 03:04 PM
MR5x5 MR5x5 is offline
Garage is empty, add now
MR5x5 is gaining momentum as a positive member of FTE.MR5x5 is gaining momentum as a positive member of FTE.
Zener Diode Boost Fooler
Anybody out there using a zener diode at the MAP sensor to limit the boost signal to the PCM in order to avoid defueling.
Just curious if there is a downside to this method..?
Mike
__________________
2001 7.3 4x4 SC
Dp Tuner, John Wood VB, OBA, Edge Evo II (gages/codes), 6637 w/cover, 4" exh, H&H, CCK, HPX, WW, FPR, 203* stat, WARNs, Leveling Kit, Stancor GPR
  #2 (permalink)
Old 04-01-2009, 03:06 PM
superduty4x4's Avatar
superduty4x4 superduty4x4 is offline
1996 Ford F-350
My Garage
superduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud of
Popular opinion says it works. There are a few guys who caution against it for reasons I can't remember, but it had to do with damage to the MAP sensor. I have one some place... I wish I could find the bugger and install it.
I had a thread on this a while back, I'll try to dig it up.
__________________
Chase
PAA Member #2
97 F350 CCLB 4x4 PSD
96 F350 CCLB 4x4 PSD - totaled 4/17/11 and sorely missed
God speed PaysonPSD, you will be missed
ThumperTalk / All Things Moto! / Back Country Rebels / SAWS / BRC
  #3 (permalink)
Old 04-01-2009, 03:11 PM
megawatt00's Avatar
megawatt00 megawatt00 is offline
megawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputation
Why not just use an air regulator installed in the map line?
__________________
Jim
01 F350 DRW, Autometer Gauges, Custom CAI with Petes Cover, 6" Miter Stacks, 38R Turbo, Casserly SS Injectors, Live tuned by DP-Tuner (F6) , and a bunch of other stuff some show, and some go. PAA #14
www.roadsidehelpnetwork.org
RIP Robin Gone but not forgotten....RIP Mark.. I'll never forget you!!
  #4 (permalink)
Old 04-01-2009, 03:14 PM
1996 Ford F-350
My Garage
Quote:
The zener diode is easier to install and looks basically factory when done- no need to mount a regulator, run new lines, etc. Just an electronic way of accomplishing the same thing.
link 1
link 2
link 3
__________________
Chase
PAA Member #2
  #5 (permalink)
Old 04-01-2009, 03:29 PM
megawatt00's Avatar
Quote:
link 1
link 2
link 3
That was some intresting reading Chase. Thanks for the links!
__________________
Jim
  #6 (permalink)
Old 04-01-2009, 03:32 PM
smoky_diesel's Avatar
smoky_diesel smoky_diesel is offline
smoky_diesel is starting off with a positive reputation.
I think the closest zener is going to be 4.7 volt.
Not sure what the output impeadence/drive capability of the MAP sensor is but there may be an issue with the zener clamp current, depending on what diode you use. I believe the EEC-IV inputs are BJTs with input impeadence in the 10's of kohm range so it will only ask the sensor for 1ma or so. most zeners need way more current than that to hold there voltage rating (4.7volts or whatever)
I went with the ITP OBA because it is proven, simple and I didn't want to hack up the factory wiring.
Now, if you really wanted to over engineer a voltage clamp with nano second delay, use a mircrocontroller with a A/D & D/A converters and write some software
__________________
Justin
2000 F-250 PSD Lariat - 4" lift, 35 Toyo MTs, DP tuner, OBA, 4" exhaust, gauges, 6637, In-tank kit, shimmed FPR, foil delete, 1000W stereo.
  #7 (permalink)
Old 04-01-2009, 03:35 PM
1996 Ford F-350
My Garage
Now, if you really wanted to over engineer a voltage clamp with nano second delay, use a mircrocontroller with a A/D input and write some software
No need to hack wiring, just stuff the wires of the diode into the plug.
You lost me after EEC-IV
__________________
Chase
PAA Member #2
  #8 (permalink)
Old 04-01-2009, 04:01 PM
Chase, Thanks for the links. Not sure I'm seeing a definitive answer. Maybe effects the map, maybe not... Maybe need a to add a resistor, maybe not... Both the diode and a mechanical solutions have some "non-ideal" characteristics.
Being a mechanical guy who doesn't tust anything electrical, I guess I'm leaning toward the mechanical solution.
Thanks again.
__________________
2001 7.3 4x4 SC
  #9 (permalink)
Old 04-01-2009, 06:14 PM
ron's power stroke's Avatar
ron's power stroke ron's power stroke is offline
ron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud of
electronic "do-dads". a number of these were replaced due to their effect on low speed, low boost drivability. don't mess with the electronics, the PCM and MAP Sensor maintain 100% normal connectivity with no electronic interference withthe OBA..the OBA lets the map see live ###''s at that moment.. the resistor is slow to re act..
__________________
Early 99 7.3 F350 auto,TN T-4 mount with a s467 for air,SRP 1.1 for oil,H-11 stud's,"NEW" alliant 315/200 hybrids, all supplied by unlimited diesel..shimmed 910's, DI push rod's, full fuel with a fuel lab 4202,TSD sump...tuned by Gearhead..i cant wait to drop her in the truck...
http://inlinethumb43.webshots.com/50...200x200Q85.jpg
  #10 (permalink)
Old 04-01-2009, 06:26 PM
1996 Ford F-350
My Garage
Quote:
Ron- the OBA keeps the MAP from seeing boost over 23 psi (or wherever you have it set). The diode does the same thing, only by limiting voltage instead of psi. I can see where the diode could effect the sensor in other ways (I'm no electronics expert) or may be slower to react but all it does is limit the voltage the MAP sends to the PCM. Ifthe diode has no other effects on the MAP sensor I think it's a way better option than an OBA- less clutter, less cost. I really wish I could find the one I had...
__________________
Chase
PAA Member #2
  #11 (permalink)
Old 04-02-2009, 04:22 PM
all electronics operate at the speed of light.
it is the non-ideal charateristics of a diode that give the precepion of a 'delay'. the plot by ernest eugene in one of the links above shows it well
adding a resistor in series to the diode circuit to protect overloading the MAP will only make it preform less ideal, or not at all. a typical zener needs to be reverse biased and fed 20-100ma to get it to drop (or hold) it's rated voltage. the MAP isn't going to support that, it would need a voltage follower current amplifer.
__________________
Justin
Tags
03, 73, 99, boost, boosting, diode, f250, fooler, foolers, ford, hacking, map, mess, pcm, sensor, turbos
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
