location of the PCV valve? - Ford Truck Enthusiasts Forums
Old 04-01-2009, 02:23 PM
imabor imabor is offline
imabor is starting off with a positive reputation.
Red face location of the PCV valve?
I have a 2003 V6 F150 and I am trying to find where exactly the PCV valve is? It is not in the location that the Chilton Manuel says it is? Can anyone offer up a diagram?
Old 04-01-2009, 02:56 PM
PLEASE HELP! I'm getting desparate here.
Old 04-01-2009, 03:34 PM
KingRanchMan02's Avatar
KingRanchMan02 KingRanchMan02 is offline
KingRanchMan02 is gaining momentum as a positive member of FTE.KingRanchMan02 is gaining momentum as a positive member of FTE.
I don't have a V-6 in my truck like you but, the PCV valve in my truck is in the passenger side valve cover. Pictures of it in my photo album. Good luck!
Old 04-01-2009, 03:39 PM
bowdog bowdog is offline
bowdog is starting off with a positive reputation.
On the passenger side right in the middle of the valve cover, Hope this helps
Old 04-01-2009, 03:58 PM
Thanks guys you are awesome! I was tired of being treated like I was retared at the local parts store. I dont know if it was because I'm female or because I dared to question the all knowing Chilton.
Old 04-01-2009, 05:59 PM
Welcome to FTE imabor! Glad we could be of help!
Old 04-03-2009, 10:00 PM
al52269 al52269 is offline
al52269 is starting off with a positive reputation.
The milky residue you see on the oil cap is a common symptom of a bad PVC system.
PCV Basics
PCV stands for Positive Crankcase Ventilation.
All car engines have a PCV valve and it is located on top of the motor's valve cover. There is a vacuum line attached to it. It pulls out of the valve cover and if you shake it, you should hear a marble knocking inside it. If you shake it and don't hear anything, it's bad. It costs less than 5 bucks to replace.
Location
4.0L is located in the valve cover near the brake booster
5.0L is located behind the intake manifold (engine rear)
PVC Valve
Removal & Installation
1. Disconnect the oil separator hose from the PVC Valve.
2. Remove the PVC Valve from the grommet in the crankcase.
Grasp the valve and gently remove it from the grommet in the passengers side valve cover. Remove the valve from the hose by carefully twisting it out.
3. Inspect the grommet for deterioration.
To Install;
4. If necessary, replace the crankcase grommet.
5. Install the PVC Valve.
6. Install the hose.
Old 04-03-2009, 10:07 PM
rambaseball45 rambaseball45 is offline
rambaseball45 is starting off with a positive reputation.
Quote:
on my 97, 4.6L its located on the drivers side of the engine, pretty cose to the intake system
pcv valve randy6800 Ranger & B-Series 6 03-13-2008 07:06 PM
Still baffled jbondi 1978 - 1996 Big Bronco 8 09-20-2007 07:58 PM
how to replace pcv valve harryvil Escape & Escape Hybrid 2 09-18-2007 07:08 AM
PCV valve location Dustin_86 4 Cylinder Engines 0 12-18-2004 09:21 PM
pcv location 1990 4.9L f-150 paisano341 Ford Inline Six, 200, 250, 4.9L / 300 3 11-19-2003 08:00 PM
Tags
1997, 1998, 2005, 54l, 98, bad, diagram, f150, ford, located, pcv, remove, replace, truck, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
