last year for twin I beam suspension? - Ford Truck Enthusiasts Forums
Old 04-01-2009, 12:34 PM
84 f250 6.9's Avatar
84 f250 6.9 84 f250 6.9 is offline
84 f250 6.9 is starting off with a positive reputation.
just like it sounds need to know last year of that i beam suspension for my paper
Old 04-01-2009, 12:40 PM
LCAM-01XA LCAM-01XA is offline
LCAM-01XA has a very good reputation on FTE.LCAM-01XA has a very good reputation on FTE.LCAM-01XA has a very good reputation on FTE.
Uhm, I'm pretty sure they still make it, the 2wd model at least - they changed it a bit, particularly the radius arms, but tis essentially still the same thing.
Old 04-01-2009, 12:54 PM
444dieselrod's Avatar
444dieselrod 444dieselrod is offline
444dieselrod is gaining momentum as a positive member of FTE.444dieselrod is gaining momentum as a positive member of FTE.
'97 F250's were the last ones with the TTB one tons had the solid axle since the begining of time. '99 and up used a solid axle for the 3/4 and 1 tons.
Diesel Rod
Old 04-01-2009, 01:01 PM
alright thank you guys
Old 04-01-2009, 01:48 PM
RCrawler's Avatar
RCrawler RCrawler is offline
RCrawler is gaining momentum as a positive member of FTE.RCrawler is gaining momentum as a positive member of FTE.
Quote:
Diesel Rod
79 F350 had solid axle. From 80-85, the F350 was using the TTB D50. In mid '85, Ford switched to the solid D60 in DRW trucks. And then shortly after, all F350's were using the monobeam D60.
Jason
Old 04-01-2009, 02:10 PM
82F100SWB's Avatar
82F100SWB 82F100SWB is offline
82F100SWB has a very good reputation on FTE.82F100SWB has a very good reputation on FTE.82F100SWB has a very good reputation on FTE.
Twin I-beam is the 2wd front suspension, and you will still find it under 2wd S/D's and 250 and bigger E-Series vans.
TTB was an 80-97 only thing. The dates on the F350's having TTB are correct.
Old 04-01-2009, 02:36 PM
Dean88's Avatar
Dean88 Dean88 is offline
Dean88 has a good reputation on FTE.Dean88 has a good reputation on FTE.
The 98+ F150's have twin A frame, but as said the 2wd Sduties are still are twin i beam
Old 04-01-2009, 02:54 PM
David85's Avatar
David85 David85 is offline
David85 has a good reputation on FTE.David85 has a good reputation on FTE.
Best answer.
Old 04-01-2009, 03:10 PM
Indeed. One correction tho,TTB and twin I-beam is the same thing - TTB is the name of the overall design, and it can be had in I-beams (2wd) or hollow formed beams (4x4).
Old 04-01-2009, 03:15 PM
starmilt starmilt is offline
starmilt has a very good reputation on FTE.starmilt has a very good reputation on FTE.starmilt has a very good reputation on FTE.
TTB twin traction beam 4x 4 is the way I always understood it 2x was twin I beam.
Old 04-01-2009, 03:19 PM
RCrawler's Avatar
Quote:
TTB- Twin Traction Beam 4wd only
TIB- Twin I- Beam 2wd only
The basic design and function is the same, but the names aren't interchangeable.
Jason
Old 04-01-2009, 04:43 PM
Hm, okay then, guess some of the engineers working on Ford programs back at my old job never got it quite right, haha!
high beams not working eaglefire21 1994.5 - 1997 7.3L Power Stroke Diesel 11 09-29-2016 01:13 PM
Twin I-Beams jack orchard 1968-2013 Full Size Vans 9 04-04-2016 12:14 AM
I-Beam (not radius arm) Bushings causing steering and wear issues? TheKirbyMan 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 35 12-15-2011 07:41 PM
when did kingpins end? are they better than ball joints? (2wd application) Kuskoal 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 11-30-2009 10:58 PM
i beam suspension lowbudgetcustoms 1987 - 1996 F150 & Larger F-Series Trucks 16 12-14-2007 12:18 PM
Tags
50, 97, beam, beams, dually, f100, f250, f350, ford, ibeam, parts, reviews, suspension, trailer, ttb, twin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
