Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Supercharger, Turbocharger, Nitrous Oxide and Water/Methanol Injection
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 04-01-2009, 03:15 AM
madmax680 madmax680 is offline
madmax680 is starting off with a positive reputation.
03 f150 twin turbo HELP
Im looking to do a twin turbo set up on a 03 f150 with a 5.4. Please dont tell me just to find a kit for a 4.6 and bolt it on. Im the wrong guy for that. I have a tig and wire welder, all the metel tools need to do this, and also the years behind me. what i need help on is the size of the turbos. Stock 2003 f150 5.4 auto 4x4, Im looking to keep the motor in one peace, so i dont need extrem amounts of boost, but i want power. please dont just tell me that i need a t3/t4 turbo times two. i need the sizes of everything. so that i can find the right one's. the turbos are going under the cab of the [COLOR=green! important][COLOR=green! important]truck[/color][/color], lots of empty room for a twin set-up. yes i do know i need an external [COLOR=green! important][COLOR=green! important]oil [COLOR=green! important]pump[/color][/color][/color] to return the oil from the turbos to the [COLOR=green! important][COLOR=green! important]oil [COLOR=green! important]pan[/color][/color][/color]. and i will need to have my computer flashed to a new program, i live in wisconsin so if anyone knows anyone in the state that has the background behind this to help with the computer let me know too! CAN ANYONE HELP ME OUT HERE?? dose anyone have all the right numbers to put into the turbo caculaters to find out the right size i need??? please email me at ( ridersofthestorm680@yahoo.com ) Thank you
  #2 (permalink)
Old 04-01-2009, 08:42 AM
meanv10's Avatar
meanv10 meanv10 is offline
meanv10 is starting off with a positive reputation.
Quote:
Originally Posted by madmax680 View Post
Im looking to do a twin turbo set up on a 03 Silverado with a 5.4. Please dont tell me just to find a kit for a 4.6 and bolt it on. Im the wrong guy for that. I have a tig and wire welder, all the metel tools need to do this, and also the years behind me. what i need help on is the size of the turbos. Stock 2003 Silverado 5.4 auto 4x4, Im looking to keep the motor in one peace, so i dont need extrem amounts of boost, but i want power. please dont just tell me that i need a t3/t4 turbo times two. i need the sizes of everything. so that i can find the right one's. the turbos are going under the cab of the [COLOR=green! important][COLOR=green! important]truck[/color][/color], lots of empty room for a twin set-up. yes i do know i need an external [COLOR=green! important][COLOR=green! important]oil [COLOR=green! important]pump[/color][/color][/color] to return the oil from the turbos to the [COLOR=green! important][COLOR=green! important]oil [COLOR=green! important]pan[/color][/color][/color]. and i will need to have my computer flashed to a new program, i live in wisconsin so if anyone knows anyone in the state that has the background behind this to help with the computer let me know too! CAN ANYONE HELP ME OUT HERE?? dose anyone have all the right numbers to put into the turbo caculaters to find out the right size i need??? please email me at ( ridersofthestorm680@yahoo.com ) Thank you
unless you did an engine swap, or april fools joke, your chevy has a 5.3L
__________________
03 F350 v10
Kb supercharger
Autometer gauges
35" Baja Mtzs
  #3 (permalink)
Old 04-01-2009, 03:12 PM
thats not a real funny april fools joke, changing all the ford/f150/250 to all chevy tearms. i dont think when someone is asking for help, and all their words get changed.
  #4 (permalink)
Old 04-21-2009, 06:19 PM
enduro4231's Avatar
enduro4231 enduro4231 is offline
enduro4231 is starting off with a positive reputation.
There isn't just someone sitting around out there waiting to hand you over all the exact spec's you need to twin turbo your engine. There is alot of research and factoring that needs to be done. How much boost do you want to run? This will ultimately determine the size of the turbos that you need. Why do you need twins in the first place? If you want high-teens and above for boost numbers your heads will try to separate from your block, so O-Ringing is a good idea as are ARP head studs. You will need your PCM reprogrammed to recognize boost, as well as a MAF with the range for boost. Wideband O2 sensors aid in tuning greatly. You'll need a higher volume fuel pump and larger injectors to supply all that incoming air with a sufficient volume of fuel. Ultimately, it's what you want. There is no book on 'how to twin turbo my F150' as every application is different. I suggest you start by reading Hugh MacInnes' book 'Turbochargers' one or more times, and really take it all in. Then YOU decide how big of turbos you need. You will need an intercooler to keep your EGT's down below 1500, and an oil pump capable of keeping the turbos lubricated. It isn't as simple as you want it to be.
Most people don't realize that turbocharging a new EFI engine, particularly an OBDII engine, is MUCH more involved than simply bolting up some turbos and plumbing the intake/exhaust.
__________________
2002 F250 Lariat 5.4L, 4x4, Auto: Magnaflow Exhaust; K&N Intake; SCT X3 w/ 5 Star Tunes; Leveled on 35" XTerrains on MT Classic Lock wheels; Manual TC Lockup switch; Recon Smoked Cab lights
I love to weld!
Tags
03 , 2001 , 2002 , computer , f150 , ford , programming , setup , size , truck , turbo , turbochargers , turbos , twin , twins
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
