5R55E Transmission problems
Old 03-17-2009, 10:50 PM
sknaggs185's Avatar
sknaggs185
sknaggs185 is offline
I have a 2000 ford ranger with the 5R55E auto trans. and having shifting problems with 4th and 5th gear. DTC's P0734 and P0735 (incorrect gear ratio) have come up for the second time!! First time when transmission was rebuilt, and now, 2 years later! anyone have any suggestions?
Old 03-17-2009, 10:59 PM
Old93junk's Avatar
Old93junk
Old93junk is offline
5R55E trans is a "problem child" according to some folks, try posting up in the transmission forum or in the Ranger/ Bseries forum........Sorry, couldnt be more help!
Old 03-18-2009, 06:42 AM
fabmandelux's Avatar
fabmandelux
fabmandelux is offline
Welcome to FTE The best place to find an answer to your problem would be here: https://www.ford-trucks.com/forums/forum69/
Or here: https://www.ford-trucks.com/forums/forum35/
I approved your membership in the Oregon Chapter this morning. Post up and tell us a little about yourself!
Dave............You almost let another "wetsider" get away! You need all the help you can get over on your side!
Old 03-18-2009, 11:20 PM
Old93junk's Avatar
Old93junk
I must have been sleep posting!,.......Yes welcome to FTE ......AND the Oregon chapter!
Where on the wetside are you coming from?
Old 03-19-2009, 10:42 PM
sknaggs185's Avatar
sknaggs185
I am from Dallas, by Salem. Have been in a Ford family my whole life, and continue the trend. i have my Blue 2000 Ranger, and a two-tone white and brown 1999 F-350 Diesel. I have had numerous fords...a 65' F-100 (should have kept that one, definitely) a 1990 F-150, and still have my two newer Fords. in my direct family, there are a grand total of 8 Fords.
Old 03-19-2009, 11:14 PM
Old93junk's Avatar
Old93junk
Welcome to the chapter!, Have you had any luck getting the prob. cornered yet?.
Old 03-19-2009, 11:23 PM
sknaggs185's Avatar
sknaggs185
no luck yet...but it will prevail. i am going to retrieve all of the information from the transmission shop i took my ranger into 2 years ago, so i can use that to corner the problem a little more. Another thing- its strange how all of this started with just the reverse band breaking. before the transmission was rebuilt, all of my forward gears were fine, even at 130,000 miles. Only AFTER i had the transmission rebuilt, did it start having these different types of problems...
Old 03-20-2009, 08:13 AM
Old93junk's Avatar
Old93junk
I can give you the number of a VERY good trans. shop with a Ford specialty, but he is in Springfield so it may be too far to matter................How long was your warranty good for?
Old 03-21-2009, 08:45 AM
sknaggs185's Avatar
sknaggs185
Smile
My warranty ended 1 year ago...in may. Today, i am going to pick up the papers concerning what they did exactly to fix this problem before. At least, it will help me get one step closer in the right direction. If you have the number for that transmission shop, i will call him and at least give him the info that i have, from this other transmission shop. thanks....the help is much appreciated.
sknaggs185
Old 03-21-2009, 12:11 PM
Old93junk's Avatar
Old93junk
sknaggs185
Here you go!,----(541) 726-6824. Tell him one of his cust. referred you. Even though its a Aamco, this guy DOES NOT fit that mold , he is VERY good, honest and knows his Ford products. Been using him for years and have NEVER been bitten, in fact, many times he has actually charged less than he quoted on jobs.......Does EXCELLENT WORK.
Old 03-22-2009, 11:36 AM
sknaggs185's Avatar
sknaggs185
thanks for the number..i will call him tomorrow. I didnt' really get much out of the trans. shop i took the ranger into...he basically told me they didn't "document work that came back," but he did tell me it had to do with the valve body. he said the solenoids were replaced with the valve body replacement, and that there is a manual position lever on the side of the transmission that could possibly fail...but why would it go through three gears and not the rest? doesn't really make sense for that part to go out... however, i got the paperwork for what they did the first time....not real extensive, but they did the job. sounds like something electronic, being there is no faul smell to the fluid.
Old 03-29-2009, 09:39 PM
sknaggs185's Avatar
sknaggs185
well...i haven't had the time to make the call, and the transmission has since gone downhill. i ran the live scanner on it and the solenoids shift ok, but once it's ready to shift into 4th gear, it says it shifts, but i feel no shift at all, just feels like the same gear, but it has much hesitation at that point. Reverse is delayed....now the transmission fluid smells burnt, unlike before. I'm wondering if maybe there is a fluid deficiency in 4th and 5th gear. sounds like i need to make the call tomorrow for sure....
Old 03-29-2009, 10:25 PM
Old93junk's Avatar
Old93junk
Make the call, he is a good guy and at the least he will steer you in the right direction.
Old 04-10-2009, 01:51 PM
sknaggs185's Avatar
sknaggs185
well, it looks as though the transmission may be shot...i talked with someone at the shop, and he said the best thing to do is to bring it out there so he can run diagnostics, but i cant even drive it. so for now, it will sit. however, i did find a shift kit that covered one of the codes, so i have purchased it, and will try that next, wipe the codes again, and attempt to drive it again.
Old 04-11-2009, 10:26 PM
Old93junk's Avatar
Old93junk
Keep us posted on the status, not too hard to pull that trans. yourself and eliminate all the labor $$$.
lmarkie
05-01-2017 09:03 PM
daBeaver
07-07-2016 08:03 PM
miked_939
04-11-2015 11:38 AM
fordbroncodave
1978 - 1996 Big Bronco
07-13-2011 07:06 PM
MRStace84
1983 - 2012 Ranger & B-Series
31
08-06-2009 02:39 PM
Quick Reply: 5R55E Transmission problems
