Bent Pushrods on my 1997 7.3 Powerstroke - Ford Truck Enthusiasts Forums
Old 03-31-2009, 07:16 PM
millmike millmike is offline
millmike is starting off with a positive reputation.
Has anyone experienced or heard of pushrods bending? Driving down the highway last week my truck began missing and running badly. Upon removal of the valve covers I found #2 cylinder had bent pushrods a broken lifter retainer, the lifters were out of place just laying there. Any ideas what may have coused this?
Old 03-31-2009, 07:23 PM
KevinC.'s Avatar
KevinC. KevinC. is offline
KevinC. is gaining momentum as a positive member of FTE.
Hydrolock? I've read of a few other guys this happened to on here.
Old 03-31-2009, 07:37 PM
I can’t imagine how that could happen????? I was driving 65 mph at 2200 rpm when my truck began missing and running bad, It would blow white exhaust when I accelerated after that. I may have hydrolocked it when starting it after that.
After re-starting it never blew white exhaust again.
I am trying to understand what may have happened before replacing the pushrods and lifters.
Old 03-31-2009, 08:36 PM
c00nhunterjoe's Avatar
c00nhunterjoe c00nhunterjoe is offline
c00nhunterjoe has a very good reputation on FTE.c00nhunterjoe has a very good reputation on FTE.c00nhunterjoe has a very good reputation on FTE.
lifter could have seized
Old 03-31-2009, 08:52 PM
kawa's Avatar
kawa kawa is offline
kawa has a good reputation on FTE.kawa has a good reputation on FTE.kawa has a good reputation on FTE.
Millmike:
Had you done any type of maintenance or work of any type on the engine immediately prior to this happening?
Did you or have you ever used starting fluid to start this engine?
Just fishing.
Rog
Old 03-31-2009, 09:00 PM
Diesel_Dirk's Avatar
Diesel_Dirk Diesel_Dirk is offline
Diesel_Dirk is starting off with a positive reputation.
I had a bent pushrod on mine when I got it, had a headgasket replaced prior. My guess it was installed or it hydrolocked because they didnt empty all the fluids from the cylinder.
Good news is they are real cheap from Ford....like $40 for 4...had to buy a pack of 4 in my case.
Old 03-31-2009, 09:23 PM
A seized lifter make since to me.
The only maintenance in the last couple of months was an oil change, fuel and air filters. This truck has never had a valve cover removed prior to this.
I have used starting fluid to start the truck a couple of times on very cold winter days in Jan.. I sprayed a quick shot into the air filter housing prior to cranking the truck.
Old 03-31-2009, 09:28 PM
My intake lifter came out in pieces, I believe my exhaust valve is bent.
There is a little mark on the #2 piston indicating to me the piston hit the exhaust valve.
I am puzzled on how this happened.
Old 03-31-2009, 09:35 PM
strokin'_tatsch's Avatar
strokin'_tatsch strokin'_tatsch is online now
strokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud of
lost the valve seats?
Old 03-31-2009, 09:48 PM
I am taking the head to the shop tomorrow to have it thoroughly checked out, and most likely the exhaust valve replaced.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old 04-01-2009, 05:34 AM
tjbeggs's Avatar
tjbeggs tjbeggs is offline
tjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to all
weak valve spring can cause it too. How many miles on the engine?
Old 04-01-2009, 07:23 AM
Cuda_jim's Avatar
Cuda_jim Cuda_jim is offline
Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.
Quote:
Well now, there's your problem! Ether will bend push rods. You're lucky there wasn't an explosion...well maybe there was, but it happened in the cylinder instead of intake.
Old 04-01-2009, 08:52 AM
The truck has 135K miles.
Old 04-01-2009, 08:56 AM
Quote:
Thats a possibility I guess.....
Old 04-02-2009, 12:32 PM
DRRXR's Avatar
DRRXR DRRXR is offline
DRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputation
Check out this thread, some pics are in there as well.
http://www.ford-trucks.com/forums/82...ve-covers.html
Bent push rods Tinytune812 1973 - 1979 F-100 & Larger F-Series Trucks 29 02-22-2017 04:25 PM
1976 460 help william16339 1973 - 1979 F-100 & Larger F-Series Trucks 2 05-27-2016 06:53 PM
how to straighten pushrod guide in headgasket TheBlueMule 6.0L Power Stroke Diesel 2 05-18-2015 06:59 AM
Help with pushrods ford141 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 10 03-03-2013 12:19 PM
Bent pushrod ford truck oldboy460 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 9 01-28-2009 09:28 AM
Tags
1996, 1997, 73, bad, bent, f250, ford, instalation, lift, power, powerstroke, push, pushrod, pushrods, rod, rods
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
