pulleys won't line up
Hi all, I'm putting a 351w in place of my 302 in a 79 F100. After bolting the 302's pulleys on the 351w the crankshaft pulley sticks out further than the alt and water pump pulleys a little more than a 1/16 inch. Not alot but noticeable. I'm worried about throwing the belts off. Both balancers are exactly the same. Measuring from the end of the crankshaft back to the timing chain sprocket there's .073 in. difference. The 302 having the larger dimension of the two which puts the balancer and pulley closer to the engine. Has anyone had this problem? I'm thinking of milling .073 off the back of the balancer. Any advice would be GREATLY appreciated. Dave
Pulley alignment
Some pulleys will be interchangeable if they are from similar years. I suppose yours don't fall into that category.
I think an easier fix than machining parts would be to get some sixteenth inch thick, or .073" thick aluminum or other sheet metal and cut spacers to shim out the alternator pulley and water pump pulley. The layout of holes on these spacers does not really need to be that precise, as the alignment of the pulleys is still determined by the close fit on the shafts.
Buyerz
06-19-2016 09:45 AM
