i have an 05 f150 i cant seem to get the running lights to work everything else works fine (on the truck) on the trailer plug is there a seperate fuse for that?
running lights on the trailer are tied to tail lights, right? yes, there is a fuse under the hood on the drivers fender well. i have had it blow a couple times. on my trailer, you need to have the truck not running when you plug in the trailer. if it is running, it normally blows the fuse.. i dont remember the exact one, but its probably yellow (20 amp), and the small C shape.
