'03 rear end noises
'03 rear end noises
hello everyone.
I have an '03 f-150 2wd. when i make a turn from a stop the whole rear end of the truck gets a bad vibration in it and as i make the turn there is a squeaking from the rear end. the vibration also happens from a stop and accelerating to go straight. feels like something is slipping in the rear end. The whole truck vibrates when this happens.
Similar Issue
03 FX4 with the same problem
My 2003 SCrew FX4 (5.4/3:73 gears/limited slip diff) with 72700 miles on it did the same thing last week...had the shudder/vibration during shallow turns (1/2 to 1 turn of the steering wheel) at low speed and upon acceleration. After a 26 mile drive home, rear end was "howling."
Dropped it off at the dealer, they replaced the "Gear and Pinion and Diff Clutch Packs per TSB 05-23-30."
