Go Back   Ford Truck Enthusiasts Forums > Misc. > Electrical Systems/Wiring
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 03-31-2009, 12:47 AM
downhillpat downhillpat is offline
2001 Mercury Mountaineer
My Garage
downhillpat is gaining momentum as a positive member of FTE.
Question Flickering Lights and Voltmeter plus more!!!
My 87 is giving me troubles...Mainly with the gauges, blower motor, and headlights.
I did have trouble awhile back...
The first was all the instrument backlights went dead, which burned a fusible link, replaced link, is ok.
Then the 2G alternator caught on fire, so I swapped to a 3G reman from a 95 taurus bought at autozone (cringe) I made my own wiring with a 4 ga cable to from alt to a 150 amp resettable circuit breaker. The yellow wire follows it to that side of the circuit breaker. It runs straight to the battery after the breaker. The white and black stator wire is run to the single terminal on the alt and also splits to the carb for the choke. I don't know if it makes a difference but there is only one v belt driving the 3G, and I keep it tight and true.
Then about a month later it pulled the old starter stays engaged trick. That warranted me to swap to a motorcraft reman mustang starter (same as the Ford Racing mini starter with the same style and gauge wiring from the kit that is like a 93 mustang with a 5.0) which works flawlessly. Has a motorcraft fender relay as well.
And ever since the starter crapped out, the lights have been flickering along with the gauges and engine rpm... When the headlights are turned on, oil pressure gauge almost touches the last white line. If the engine is warm, the temp gauge follows suit. The voltmeter however drops down to the 12-13 volt range and forget about the blower motor, turning that on lowers rpms and makes the wipers move slow. Blower motor is also brand new motorcraft not even a month old as well as resistor and pigtail. (it was making noise) My kenwood head unit will also turn on and off from what seems like not enough voltage or maybe amperage to run in the same manner as the flickering headlights...
Franklin...what say you???
__________________
Mountaineers are not boats..
2005 F-250 SD XLT 5.4 3v ZF S6-650 3.73LS Kinda bone stock right now...
1987 F150 XL 4x4 351W, 4 bbl, C6, BW1345, 3.55 On the road...
1994 F250 XL 4x4 351W, EFI, ZF5, BW1356, 4.10 Sold it but I still wrench on it
  #2 (permalink)
Old 04-02-2009, 12:06 AM
Franklin2's Avatar
Franklin2 Franklin2 is offline
1989 Ford F-250
Franklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud of
Make sure the ground wire from the battery to the engine block is ok. Also make sure you have a ground strap from the engine block to the firewall sheetmetal.
If none of that works, take the alternator back and see if it passes on their machine.
__________________
Dave F
1989 F250 XLT Diesel
  #3 (permalink)
Old 04-02-2009, 09:11 PM
My Garage
Now that you mention it...it has been a while since I disturbed that ground back there...will check it out.
Pat
__________________
Tags
blower, drops, motor, turned, voltmeter
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
