Squeaking Alternator
Put a new alternator less than 20k miles ago on the Excursion (2000 PS Diesel). There is a squeak in the front of the engine. I took the belt off thinking it may be time for new idler pulleys, but lo and behold it is the relatively new alternator making that noise, even if I just turn the pulley with my hand.
Is this a sign that the bearings are going out? Or is there a chance that something is wrong with the brushes and I can get away with a $50 repair at the alternator shop?
Finally, if you think I should replace it, what's a good quality replacement? I bought a quality part through my local independent parts dealer, but the warranty has expired.
Right now I am leaning towards getting a replacement from AutoZone. This thing is R&R so quickly, at least there I get free lifetime warranty.
Thanks in advance for you help!
George
George
Could be the front bearing, a slight rub of the rotor to stator, or slight rub of the fan.
If you feel a little roughness when you turn the shaft then it is the front bearing. A bearing can be replaced without much cost. You could go to an alternator repair shop to install a higher quality bearing that will last longer and have better seals.
If the alternator turns but sticks a bit on every revolution then it is likely a rub. Easiest to just replace the whole unit.
Brushes are mostly carbon and copper. They won't squeal like that.
Replace it
This bearing replacement is a waste of time, just do like the guys above said and buy the autozone special with the life time warranty and forget about it. The steps and time that it would take to replace the bearing you could have a new alternator installed, and not have to worry about it for another 100K, plus you get the warranty replacement when the time comes, not a bad deal.
We build machinery at work, from raw metal and parts, I have access to everything you could imagine, except sheet metal tooling (brakes, english wheeels, etc).
One time I needed a part for a 40 year old boat so I just had it made.
I just wondered if anyone new what the bearing size or number was so I can go ahead and buy it ahead of time. I REALLY hate spending 200 bucks for a couple 5 dollar bearings.
cman1120
27
01-26-2016 05:21 AM
Macs1964F100
12-11-2014 08:55 PM
Mike8623
07-17-2011 07:04 AM
4WheelDriveVan
1997 - 2003 F150
12-10-2010 07:30 AM
