Alternator change
Old 03-30-2009, 05:19 PM
hdman6's Avatar
hdman6
hdman6 is offline
Question Alternator change
Hi all, I tested my alt tonight and it is only pushing out 12 volts when the truck is running with no acc or lights on. So I need to replace my Alt. I have a 110 amp single setup. So dealer gets $230.00 with core change. Now my question is to remove the belt i need to move the pully but does it take a socket head or just a drive extension with a breaker bar to push it down and how hard it it to push down and slip off the belt at the same time. I hope to do it in the dealer parking lot so i can give them the old one right there. Also the new one (ford)has the pully on the alt right? thanks Jeff
Old 03-30-2009, 05:25 PM
Bergerson's Avatar
Bergerson
Bergerson is offline
Just a thought I picked one up from a local wrecking yard for $50.00 when I neeeded one a year or so ago, still working fine...just a thought
Old 03-30-2009, 05:30 PM
triskit16's Avatar
triskit16
triskit16 is offline
1/2 breaker bar...no extension...just the drive itself. IIRC pull toward yourself if youre on the passenger side and just slide the belt off one of the pulleys and release and you can go to work on the alternator. Alternator should come with the pulley on it already from dealer.
Old 03-30-2009, 05:34 PM
superduty4x4's Avatar
superduty4x4
superduty4x4 is offline
You can buy them all day long on Ebay for 1/2 that price.
1/2 breaker bar in the slot on the tensioner (passenger side of motor) to remove belt. 3 bolts and one small nut to pull the alt out. Takes 20 minutes on the side of the road with crappy tools... ask me how I know this
Old 03-30-2009, 05:47 PM
rbaker6336's Avatar
rbaker6336
rbaker6336 is offline
Old 03-30-2009, 05:58 PM
danskool's Avatar
danskool
danskool is offline
Go Bills !
I just did this the other day. Got my fingers stuck under the regular 1/2" ratchet and the water pump pully. I was to lazy to get the 1/2" drive breaker bar. (or rather look for it).
So laying on the radiator reaching in. Pull up with left hand and slip belt off of alternator with right.. Don't get you fingers under it when you go back down. That spring it tough.
And make sure you have the belt diagram someplace on your radiator support deck so you don't have to hassle with guessing if the belts gets jumbled. You can do it in the parking lot. No problem if you have 1/2" drive breaker bar.
I would never pay 220 for an alternator. I would shop around for sure.
Old 03-30-2009, 06:01 PM
hdman6's Avatar
hdman6
hdman6 is offline
I looked at the DB website, I never heard of them are they good or at least as good as Ford parts would be? I dont want to be replaceing it again within a year. thanks Jeff
Old 03-30-2009, 06:02 PM
superduty4x4
As good, if not better from what I've heard of their products.
Old 03-30-2009, 06:26 PM
soutthpaw's Avatar
soutthpaw
soutthpaw is offline
Originally Posted by rbaker6336
X2 here for DB Electrical... got one on my truck and its working great...
Old 03-30-2009, 07:55 PM
maevans's Avatar
maevans
maevans is offline
Jeff - Just in case you need it.
Old 03-31-2009, 12:27 AM
87 F-150 I6's Avatar
87 F-150 I6
87 F-150 I6 is offline
I have two DB units and could not be any happier with them. You need to take off the belt but alts are really easy to change out, 30min max.
Old 03-31-2009, 12:50 AM
TP83's Avatar
TP83
TP83 is offline
I think i paid around $160 after i brought my core back to kraegen and we fixed mine in the school parking lot just gotta be able to slip the new one on and kinda pry it so you can put the bolts through.
Old 03-31-2009, 01:17 AM
brian42's Avatar
brian42
brian42 is offline
I don't have an alternator, but I've got the high torque starter waiting in the garage to go in. I've read nothing but great things about them and their starters and alternators from people here...
Old 04-12-2009, 10:28 PM
____Kilroy____'s Avatar
____Kilroy____
____Kilroy____ is offline
I just went through their search engine looking for an alternator for my 99 F150 XLT, I could not find one. I figured it would be pretty common, I emailed them but have not heard anything back yet.
Dean
Old 04-12-2009, 10:42 PM
megawatt00's Avatar
megawatt00
megawatt00 is offline
Dean
Welcome to FTE Dean
Here is the reg alt for your truck
Ford F Truck Explorer Ranger 130 Amp Alternator 92-03 7768: 7768-130 AMP REGULAR OUTPUT DB Electrical Starter-Alternator
Here is the page with the HO not to sure which engine you have
DB Electrical Starter-Alternator > ford alternator, ford truck alternator, F series alternator, alternator
Quick Reply: Alternator change
