Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Albums FAQ Members Tech Guides Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
LinkBack Thread Tools
Old 03-30-2009, 01:08 PM
GIANTOAK555 GIANTOAK555 is offline
Garage is empty, add now
GIANTOAK555 is starting off with a positive reputation.
Tire Pressure Sensor Reset
I recently installed a new set of tires and wheels on my 08 expedition, after about 100 miles I get a beep, then a message saying tire pressure monitor fault. If I push the reset the message goes away(until the engine is restarted) but the tire pressure light stays on. I took it back to the tire shop and we went around and checked all 4 sensors which are working correctly. I have found some old threads on resetting the computer in the vehicle, which includes some sort of magnet trick on the valve stem. Well it wouldn't work for me, Is there something different I need to be doing for the newer expy. Special tools maybe? Any help would be apreciated
__________________
2011 F150 Raptor SVT , Black on Black , 6.2 L[/center]
Old 03-31-2009, 03:54 PM
05 Navi's Avatar
05 Navi 05 Navi is offline
05 Navi is starting off with a positive reputation.
Ive run into that problem before... i bought new rims and tires and i had to get 4 new sensors from the dealer. The tire tech at Discount had to get a device and the instructions to figure out how to program the new sensors to the truck after i returned because i had the same pressure fault.
Old 04-01-2009, 10:37 PM
rbarbot2 rbarbot2 is offline
rbarbot2 is starting off with a positive reputation.
Last week my dash lit up with "TIRE PRESSURE SENSOR FAULT". The tire pressure was good on all tires so I figured it was a system problem.
The dealer first tried to re-calibrate the wheels and found one that would not set. So, they pulled the tire off an found the sensor disconnected and the band broken. They blamed the tire installers that put the new tires on around 3k miles ago, but they covered it under warranty anyways so I was happy. I got the impression they get damaged easily during tire installations.
Old 04-02-2009, 11:17 AM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
If you take it in, tell the tire shop to please be careful as they can get damaged. A tire shop broke one of mine and said it was like that when I came in. No way, it was in pieces and it would have set off the dash light. Dealer fixed it for free.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
Old 04-02-2009, 12:01 PM
Thanks so much for the replies. Shes all fixed. I searched old threads and found that theres a procedure For resetting the computer. But the older models used a magnet to reset the sending unit in the tire, not so on the newer models. Resetting the sensor in the tire needs to be done electronically. So...went back to the tire shop, key on and off 3 times , step on brake pedal , key on and off 3 more times , then follow prompts on dash....Bingo.
__________________
Tags
2008, el, expedition, f150, fault, ford, light, pressure, reset, sensor, sensors, stays, tire, truck, warranty
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
