2002 F150 Overdrive light blinking - Ford Truck Enthusiasts Forums
Old 03-30-2009, 01:11 PM
bedwar4 bedwar4 is offline
bedwar4 is starting off with a positive reputation.
My overdrive light is blinking off and on. When I accelerate normally, the truck starts stumbling? (dont know a better word) some, sort of like a clogged air filter or fuel filter. Any ideas. I am going to take it to a transmission shop because its a little beyond me, but dont want to get ripped off.
Old 03-30-2009, 02:13 PM
triton_2002's Avatar
triton_2002 triton_2002 is offline
triton_2002 is starting off with a positive reputation.
the blinking o/d light is like the check engine light for the transmission. Has the transmission service been done on the truck? Check the transmission fluid. The transmission does not have an air filter, but there is a transmission filter that should be serviced. Take it to a couple of different shops and see if they diagnose the same problem, it could be expensive, good luck.
Old 08-04-2009, 02:30 PM
Pstroker01 Pstroker01 is offline
Pstroker01 is starting off with a positive reputation.
Quote:
I was wondering if you had that problem solved, my 2001 f250 is doing the same. Thanks.
Old 08-04-2009, 09:35 PM
bc11 bc11 is offline
bc11 is starting off with a positive reputation.
Had that happen to me when I ran my 2000 f150 4x4 over a log and it jumped up and jammed the wiring harness along the frame rail into a U channel body mount behing the Driver front wheel. Cut and mashed most of the wires. They went to the fuel pump, rear end, back part of tranny, the the tail lights. Hooked them all together with butt connectors.
Then it would run and drive in 4x4 lo but would want to stall out in 4x4 hi like it was going in 2 gears. OD light was still flashing. Found a blown blue fuse in the front of the fuse box on the engine. That fixed it and it drove all right ever since. Someone here said you could count the blinks of the OD light and pull a code but mine was just a steady on/off blink.
If not a fuse, I'd crawl under and check the connections for rust and corrosion for the wiring connectors going to the rear end and tranny. Could have run over something and broke and mashed a wire under there. Put some dielectric grease on any connections. There might be a relay acting up somewhere.
There are some dealers around looking to take the last of your 401K plan.
Let us know what you find out to fix it.
Old 08-21-2015, 12:46 PM
Crystal 33 Crystal 33 is offline
Crystal 33 is starting off with a positive reputation.
it was just the fuse
I decided to check the small things first being that the transmission fluid was full and not hot or burnt smelling. And I check this blue 15 amp fuse and replaced out because it was bad and it fixed the problem. Thank god for the internet... Thank you
Old 08-21-2015, 12:48 PM
check the fuse
Check the fuse as they explain below I was having same problems replaced the fuse and it runs great again.
Old 08-24-2015, 08:55 AM
1999_Explorer 1999_Explorer is offline
1999_Explorer is starting off with a positive reputation.
sounds like a solenoid
Old 08-24-2015, 11:48 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Quote:
Sounds like a guess... probably a wrong one.
Fuses, as a general rule, do not just blow on their own. They blow because something on the load side has pulled too much current which is almost always due to a short circuit of some kind. Chafed, pinched, burned or otherwise bare or damaged wiring is the most common concern. If you just replaced a fuse without finding the underlying reason for its opening, you'd better be prepared to get stranded down the road when the intermittent short circuit returns.
Old 10-24-2015, 08:44 AM
blinking OD light is usually a indicator of a issue in the wiring or a bad solenoid in the transmission.
not a guess...
Old 11-20-2015, 07:52 PM
MonroeHandyMan's Avatar
MonroeHandyMan MonroeHandyMan is offline
MonroeHandyMan is starting off with a positive reputation.
Pull the plug to the Neutral Safety Switch under the truck and see if any of the pins are burnt, corroded or not in place. That has happened on my 97 and my 2000 to date. Do the same on the other side of the tranny where the plug goes to the solenoid packs.
Old 11-21-2015, 12:22 AM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
Why all the guessing.
Get the transmission code read so you know what your doing.
Good luck.
Blinking Overdrive Light in '99 Expedition BriR Expedition & Navigator 13 05-29-2016 10:10 PM
Overdrive light patsalters 1999 - 2003 7.3L Power Stroke Diesel 3 09-11-2013 10:43 AM
OverDrive light blinking Vijay 1999 to 2016 Super Duty 23 06-14-2013 01:14 PM
Blinking Transmission Control Indicator Light HeyMoe 1987 - 1996 F150 & Larger F-Series Trucks 2 07-15-2006 08:52 AM
Blinking Overdrive light (on/off) on gear shift searsk Expedition & Navigator 3 11-03-2005 08:33 AM
Tags
02, 1998, 2000, 2003, 2006, 54, blinking, f150, f250, flashes, flashing, ford, light, od, overdrive
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
