Oil pan torque sequence, 302 - Ford Truck Enthusiasts Forums
Old 03-30-2009, 10:03 AM
my93 my93 is offline
my93 is starting off with a positive reputation.
have a felpro one pc gasket for a 302. anyone have a diagram for the sequence of torqing the oil pan bolts and torque values of bolts, small & large. thanks once again.
Old 03-30-2009, 10:18 AM
MBDiagMan's Avatar
MBDiagMan MBDiagMan is offline
MBDiagMan is gaining momentum as a positive member of FTE.
There's no torque sequence for the pan. Just cinch everything up evenly and don't overtighten a pan or valve cover gasket.
Old 03-30-2009, 08:45 PM
restoringmy46's Avatar
restoringmy46 restoringmy46 is offline
restoringmy46 is starting off with a positive reputation.
The one piece gasket is the way to go. I just put one on my 302 and tighten them up as close to the same as I could. No leaks at all. Like he said just don't over tighten them.
Old 03-30-2009, 09:30 PM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
start in the middle and work your way out to the front and rear. Off the top of my head, the torque value was around 10 ft-lbs.
Old 03-31-2009, 07:08 AM
thanks much
High pressure oil rail torque sequence Kdawg89 6.0L Power Stroke Diesel 7 10-04-2015 12:56 AM
oil pan bolt torque specs kevs66coupe Performance & General Engine Building 4 07-08-2013 10:45 AM
Oil pan bolts torque question cutlass 1999 - 2003 7.3L Power Stroke Diesel 1 04-03-2012 07:50 PM
Does the torque sequence on the head make a diffrence? oldtexasdog 1967 - 1972 F-100 & Larger F-Series Trucks 2 09-22-2011 10:09 AM
302 torque sequence for mains my93 Performance & General Engine Building 2 03-31-2009 01:47 AM
Tags
1978, 2002, 302, 351w, bolt, bolts, f150, ford, oil, pan, sequence, specs, torque, v8, values
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
