1993 Explorer Sport Tow Capacity - Ford Truck Enthusiasts Forums
Old 02-19-2002, 10:28 AM
ambrosia ambrosia is offline
ambrosia is starting off with a positive reputation.
Post 1993 Explorer Sport Tow Capacity
[updated:LAST EDITED ON 19-Feb-02 AT 11:28 AM (EST)]Need to know the towing capacity for a 1993 Explorer Sport. Towing a 2200lb (about) pop-up camper. No manuals for the Expy. Towed find in drive, but backing up caused problems. It is a manual transmission if this makes a difference.
Help please!!
Old 02-19-2002, 10:54 AM
ranger pat's Avatar
ranger pat ranger pat is offline
ranger pat has a good reputation on FTE.ranger pat has a good reputation on FTE.
My manual shows two ratings depending on axle ratio.
M/T with 3.27 ratio GCW 6,000 lb
M/T with 3.73 ratio GCW 7,000 lb
GCW includes your loaded vehicle and loaded trailer.
If you have a 4x4 with manual hubs like mine, you
can leave the hubs out and select 4 low when backing up
that allows you to creep slowly and maneuver without
slipping the clutch.
Old 02-19-2002, 11:07 AM
How will I know what the axle ratio is??
Do you know the empty weight of the vehicle??
Please forgive me, I am kinda dumb on this kinda stuff.
Old 02-20-2002, 01:41 PM
ranger pat's Avatar
To get the axle code, look inside the drivers door on the label. Than reference that against a page in the owners manual that decodes the letter/number into a ratio.
To get the weight of your vehicle, use 3500 pounds or get your vehicle weighed at your local truck weight station, truck service shop etc. Lots of places advertise public scales.
Old 02-20-2002, 04:48 PM
If only we had the owners manual.
Old 02-20-2002, 08:11 PM
ranger pat's Avatar
Two ways, post your axle code and I will decode it, or crawl behind the rear axle and read the ratio off the tab hanging from one of the bolts at the rear axle cover.
Old 02-21-2002, 08:34 AM
Thanks, I will get my Hubby to look (he drives it to work) and will post it later.
Old 02-21-2002, 09:33 AM
ranger pat's Avatar
It will probably either read "D4" for a 3.73 or "41" for 3.27
If it is not one of those, post the code.
Old 02-21-2002, 10:52 AM
Ok he says it is 41 so that means 6000 lbs. If we use 3500 lbs for the weight of the truck, that means we have 2500 lbs to work with. If the trailer is about 2200, and we have it totally loaded with clothes, coolers, camping gear and bikes, plus the family total weight of close to 600 lbs. I figure we should go out and buy an
F-350!!!
Old 02-22-2002, 12:00 PM
white99 white99 is offline
white99 is starting off with a positive reputation.
Old 07-25-2014, 10:56 PM
Lauren Terese Lauren Terese is offline
Lauren Terese is starting off with a positive reputation.
NEWBIE HERE! AND I'M A WOMAN WITH NO CAR KNOWLEDGE HELP!
OK SO I HAVE A 93 FORD EXPLORER XLT. 4 door. it's odometer is broken and I really don't have no clue how many miles it has on it. The odometer reads 600,000 miles.lol. It also says I travel like 30,000 miles a day. Anywho. I just got the trans rebult and I really want to tow my dog grooming trailer. The trailer weighs 1200 and it's shoreline so there are no water tanks. I just have about 300lbs of equipment on it. Do you guys think that would be ok? I looked inside my door and the label says Axel: D4. help!
P.S it only has a bumper tow thingy not a tow package but is there a way I can just buy one and have it installed? Is it worth it?
Old 07-26-2014, 06:39 AM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
Based upon above and the new tranny you can tow it.
You will want to put a receiver hitch on it. It would also recommend and trailer brake controller so that you can engage the trailer brakes to help you stop.
If you are planning on long distance travel then I would recommend a newer vehicle that is larger so that you have more room and can haul more items.
Old 07-26-2014, 09:10 AM
Chalkie Chalkie is offline
Chalkie is starting off with a positive reputation.
You do not say where you live so there are some other considerations, as well. Senix suggested a trailer brake controller, which I would agree with IF the trailer actually brakes. Not all trailers are required to have them, depending on the weight of the trailer and where you live.
Another consideration, based on where you live, is elevation. Elevation reduces your towing capacity by 3% (I think) per thousand feet. Where I live, that would be 21% and a significant factor.
As I recall from when I had a '92 Explorer, the bumper was rated for 3500# capacity. I put a receiver hitch on it as the trailer would not sit level without a lower tow point. You can get a receiver for less than $200 and they can be self-installed if you are handy as no welding is needed.
You can't really go back and retrofit a trailer towing package without spending a lot of money, and it would not be worth it on a vehicle that old.
1993 ford explorer sport camshaft sensor?? bflo1220 Explorer, Sport Trac, Mountaineer & Aviator 2 07-31-2014 12:22 AM
towing capacity - 1993 7.3 idi dcullen Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 04-07-2014 10:14 PM
1993 f150 towing capacity? aaroncarn 1987 - 1996 F150 & Larger F-Series Trucks 4 02-11-2012 08:40 AM
07 Explorer Sport Trac towing question jrkennedy Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 3 09-28-2011 11:55 PM
2000 F250 crew V10 4.30 limited tow capacity? alexisdakota 1999 to 2016 Super Duty 3 01-26-2005 07:45 PM
Tags
1993, 1994, capability, capacity, explore, explorer, exporer, ford, package, pull, rating, sport, tow, towing, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
