random vibration while driving..
Well, seem to have an issue I can't find from poking around under the truck myself... I am getting a random vibration under the truck, it hits when I roll over a bump (small, big, tiny...doesn't matter) of any kind (although not always, every bump does not start it or end it) and usually will not go away until I hit another bump (small, big, tiny...doesn't matter) I can't seem to place the location of where under the truck it is coming from as it only happens while driving feeling it in my foot and hearing it, have not been able to park it with the vibration still happening, and on that note, I "think" that it always goes away if I roll to a stop..
Half the time is rolls no with no vibration at all, other half... it's not bad enough to stop me from driving, just irritating as all hell, I thought that the 4" exhaust that I had installed around 7 months ago had just finally settled and was maybe resting on a crossmember, but got under on the creeper, everything is as tight as I left it.
Ideas?
Ideas?
not all the time, randomly starts and stops the vibration when hitting any kind of bump, small, large, you name it....thats the only pattern
edit: triskit16, can you explain the vibration, how it felt..did you feel that mainly in the steering wheel? I can't say thats where I am feeling it.
I couldnt find a pic online so I went out and took a pic of mine. Mine is yellow but yours might still be black (I think) if you even have one. Take it off and see if acts like a normal shock or if it has no resistance at all.
I honestly dont know what this damper actually dampers as far as what caused my cobblestone feel, but it stopped it for less than 100 bucks!
Could be a possible bad wheel bearing as well...Im not sure. Jack up each front tire and grab the tire at 12 and 6 o'clock positions(I believe) and see if you can get any play in it. If so you have a bearing issue.
Make sure you dont have the steering damper though. It could be black and its not as pronounced or visible if its still the stocker on there. Kinda blends in with everything.
Have you had it in 4x4 lately? I would try to engage it on a gravel road drive a little ways, then back up and try to take any bind out of the drivetrain then disengage and see if anything changes. I had something similiar to what you describe on an '88 Wrangler, and this "fixed" my problem. Good luck!
