Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2004 - 2008 F150 2004, 2005, 2006, 2007 and 2008 Ford F150's with 5.4 V8, 4.6 V8 or 4.2 V6 engine SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 04-18-2009, 04:27 AM
fordsinair fordsinair is offline
fordsinair is starting off with a positive reputation.
Thank you very much. this is what I've been looking for for quite a while now. Maybe I can finally get that frikkin halfway engaged problem fixed. I know that's tearing parts up bad. And hopefully get the mileage above 9MPG.
  #17 (permalink)
Old 06-01-2009, 03:10 PM
Fishin76 Fishin76 is offline
Fishin76 is starting off with a positive reputation.
Did all the tests, everything looks good, still grinds.
Ok, I did everything in the write up, except drive with the gauge hooked up.
Idle vacuum was 20-24, everything from the T at the solenoid holds to the IWE actuators hold vacuum with NO leakdown as observed. System holds vacuum for 5 seconds after shutoff, (until the solenoid opens and lets air in)
Getting to this point, I got rid of the checkvalve at the sloenoid, and replaced the one on the intake vacuum port with a much better ball and spring type. Checked everything in the write up, plus some.
in January, I had replaced the (drivers) left side IWE actuator, which is grinding again. (it holds vacuum just fine).
My symptoms are grinding in OD (4th gear) when accelerating, (even a little makes it grind). I know it is a IWE, so lets not talk about any other diagnosis.
In the morning, doesn't do it. when all warmed up, touching the accelrater with my big toe will make it grind in OD, and sometimes in 3rd.
I can't find any leak. HELP.
__________________
These are not the Droids you are looking for.....
Current vehicles:
98 Contour 2.0L auto, my new DD 49K 30mpg
2009 Dodge Grand Caravan SXT 3.8L 6sp auto
1986 F250XL Diesel RC LB 4x4 T19 4spd 4.10's?
  #18 (permalink)
Old 06-01-2009, 10:07 PM
sherwin johnson sherwin johnson is offline
2006 Ford F-150
sherwin johnson is starting off with a positive reputation.
make this thread a sticky guys
__________________
06 SUPERCREW
2.5" PRO-COMP LEVEL KIT
DUAL CAT-BACK EXHAUST
285-70R17 NITTO TERRA GRAPPLERS
X3 FROM MIKE AT 5 STAR TUNING
FORD ROCKS!!
  #19 (permalink)
Old 06-02-2009, 08:11 AM
xjcamaro89 xjcamaro89 is offline
xjcamaro89 is starting off with a positive reputation.
I know it sounds stupid but check and make sure the check valve is facing the right way. Also you might want to put the second check valve back in, it was there for a reason. You might want to rig something up to watch the guage while your driving and see how the vacuum drops, if at all. Your vacuum might be fine. Just some thoughts.
  #20 (permalink)
Old 06-04-2009, 09:42 AM
Hey all, I found a manufacturer that will send you free samples (up to 5 items) of vacuum check valves.
Ark-Plas® Products, Inc. - Manufacturer of Plastic Fittings, Tubing, Decorative Screw Covers and Quick Bind Hardware
and free us mail shipping. All you need to fix your trucks is 2, so its worth a shot
Mine are on the way......
__________________
Current vehicles:
  #21 (permalink)
Old 07-02-2009, 04:29 PM
GO45 GO45 is offline
GO45 is starting off with a positive reputation.
IWE Noise
This is my 1st post....so much info here, it's great....thanks for the detail...it has helped me a lot.....so I also have the grinding noise everyone is talking about in my 2004, F-150 4x4 front-end....it was happening off and on for some time, it seemed, but then it was all the time, but only got noisey when my speed reached 40-50 km/hr....so I did as mentioned; I disconnected the vacuum line ahead of the 1st check valve, on the engine side, and plugged it both ways....so that I could still drive it (both hubs would be engaged) and that got rid of the noise...now 3 weeks later, I finally got a good vacuum tester and some free time...I removed both hoses at the hubs and got minimal or no vacuum on the hubs at the larger fitting...so then I reconnected the vacuum line that I disconnected and plugged off 3 wks ago, near the firewall, put the vacuum tester on the hose at one hub, and with the hose to the other hub plugged off, I started the engine, and the vacuum rose to 22 in. hg...
so I reversed the tester to the other hub vacuum line and same result...I also switched into 4x4 high, and the vacuum went to 0 and then when switched back to 2 wheel dr.the vacuum increased to 22 in., so that proved the solinoid to be working ok... so now I believe both actuators need replacing...I found out that only Ford carries these parts, so I guess that's my next stop....My next question is, can someone tell me, in some detail and/or sequence , how to remove the parts required to get the actuator replaced? Thanks in advance, and have a great day....
  #22 (permalink)
Old 07-03-2009, 11:37 PM
melek4me melek4me is offline
melek4me is starting off with a positive reputation.
this may help.
http://www.f150online.com/forums/200...replacing.html
  #23 (permalink)
Old 08-13-2009, 08:30 AM
Engine's Avatar
Engine Engine is offline
Engine is starting off with a positive reputation.
Great post. I have been having the same trouble. I just got my 2005 F150 out of the shop where they replaced both hub assemblies, and I still have the grinding sound on acceleration.
Must be a vacuum leak somewhere. I will start down your list of checks.
Thanks again for the post.
__________________
Steve
1988 F150 Custom 4X4 300 - 6 5 spd trans
1992 F150 XLT 4X4 300 - 6 4 spd trans
1995 F250 XLT 4X4 351 5 spd trans
  #24 (permalink)
Old 08-13-2009, 08:33 AM
That would be your best bet. Check all your hoses and fittings. You can now at least exclude the actuators from being bad.
  #25 (permalink)
Old 08-16-2009, 10:19 PM
fastbmw01 fastbmw01 is offline
fastbmw01 is starting off with a positive reputation.
Good Stuff! I don't think thats my issue???
but my problem is, I know it locks in and out, but I get know inst. clust. indication for 4x4H! 4x4L does light up! 4x4H indication does flicker as it shifts in and when disengaging!????????but just won't stay lit ????
  #26 (permalink)
Old 08-31-2009, 03:04 PM
That would be your t-case shift motor. Bang on it with a hammer.(lightly) and it should work for a while longer, but plan to replace it soon.
__________________
Current vehicles:
  #27 (permalink)
Old 09-06-2009, 09:11 AM
BMLocal175 BMLocal175 is offline
BMLocal175 is starting off with a positive reputation.
Well I have these symptoms on my truck and was wondering what kind of costs I'm looking at to drop it off at a Ford dealer and have them do it?
Mine started making the grinding, hissing noise on the left front and is continious now at all speeds. I engaged the 4x4 and it all stops. Can I drive it at all either way or get it fixed now? My commute now is a 4 man car pool with me driving every forth day at 120 miles round trip.
Pete
__________________
________________________
Pete
2005 Ford F-150 SuperCrew FX4
MODS:
Ford Rubber Bed Mat w/ F-150 Logo
Ford Hard Shell Tailgate Liner
Magnaflow 16614 SIDO
  #28 (permalink)
Old 09-10-2009, 05:11 PM
Just a quick update for those of us who can't do it themselves or don't have the time.
Picked it up today from ford and they put in 2 new actuators, cleaned the lines and new solenoid with the new rain guard or whatever its called. They said the left where I was hearing the noise was seized up and the right was hanging up.
$271 parts
$418 labor for 5.5 hrs
Is this the norm?
__________________
Pete
MODS:
  #29 (permalink)
Old 09-11-2009, 09:19 AM
Glad you got it fixed. What you could have done (and it probably would have been nice to know this before) to drive it without hurting anything was to disconnect the line coming off the intake going to the solenoid and plugged both ends. This would have at least engaged the hubs, but not put you in 4WD. But that is all behind you. The service bill doesnt look too bad. But just for a perspective i did it myself, and keep in mind i have all the tools and lots of mechanical experience, but never did one of these before. I did both sides the first time in under three hours. When i had to re-replace the one side a month ago, i had the whole side tore apart old part out, new part in, all back together in under an hour. So imagine how long it should have taken the techs to do it with a lift and all the "right" tools. probably at the most 2 hours, but thats water under the bridge. Hope the truck works for ya for a long time.
  #30 (permalink)
Old 09-11-2009, 05:14 PM
Yeah I figured the hours were a little high but i wasn't sure if I could haggle with that or that is set in stone. Do people haggle with prices for repairs in a ford shop?
__________________
Pete
MODS:
Tags
2005 , 2006 , 4x4 , actuator , bad , buy , f150 , ford , hub , iwe , online , problems , solenoid , symptoms , system , vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
