Everything You Wanted To Know About The IWE System...And Then Some - Page 16 - Ford Truck Enthusiasts Forums
  #226
Old 11-02-2011, 08:46 PM
davevassar davevassar is offline
davevassar is starting off with a positive reputation.
So, I'm dumb when it comes to this stuff. Are there 2 lines coming out of the solenoid? Just want to make sure I pull the right thing. Then I plug the line I take off?
  #227
Old 11-02-2011, 08:49 PM
xjcamaro89's Avatar
xjcamaro89 xjcamaro89 is offline
xjcamaro89 is gaining momentum as a positive member of FTE.
There is a single line coming from the engine to the solenoid. Pull that one off either at the solenoid or at the inline check valve half way between and plug the end coming from the engine so the engine isnt sucking air until you get it fixed.
  #228
Old 11-02-2011, 09:06 PM
Thanks guys. Just none thing, I have it in 4H, but it's not actually engaged, so if I pull the line and put the switch back to 2wd, it will be fine until I get it fixed?
  #229
Old 11-03-2011, 07:36 AM
xjcamaro89's Avatar
Yes, when you pull your line, it releases the vacuum to the hubs, releasing the vacuum locks them in, so when you pull your line, and switch to 2wd, your font axle will be locked to the wheel, but not driven by the transfer case. This scenerio happens alot when the vacuum system stops working for the 4wd in these trucks and the owners dont know (like mine). But what you might want to check out is if your transfer case switch is working. This is a little motor on the side of the transfer case that switches the drive line to 4wd, if this isnt switching all the way, it could trigger the 4wd light on the dash but not actually switch into 4wd. But i would just point this stuff out when you take it in. Without more detailed info i cant pinpoint the problem for you, but not worries if your taking it somewhere.
  #230
Old 11-03-2011, 10:40 AM
Thanks a million!
  #231
Old 11-03-2011, 10:53 AM
xjcamaro89's Avatar
And to tell you the truth, before i even noticed what my truck was doing, i bet i drove around 6+ months like that before i even did anything, and so far, no ill effects. Oh, and 4wd will still work fine (as long as the problem isnt you switch motor on the transfer case)
  #232
Old 11-14-2011, 08:13 PM
So, I was thinking, could this have happened when they replaced my tranny? I noticed a slight rattle about a week after I picked it up, then after the freak snowstorm, I used 4wd and that's when it really started grinding and all that. I'm thinking about bringing it back to the dealership that did the tranny and demanding that they cover it under the warranty that came with the tranny. What do you guy think?
  #233
Old 11-16-2011, 03:41 AM
Kmsalvadore Kmsalvadore is offline
Kmsalvadore is starting off with a positive reputation.
these posts are a help anyone know where I can get instructions on how to replace a IWE actuator??
  #234
Old 11-16-2011, 07:16 AM
60DRB's Avatar
60DRB 60DRB is offline
60DRB is gaining momentum as a positive member of FTE.60DRB is gaining momentum as a positive member of FTE.
  #235
Old 11-16-2011, 07:17 AM
xjcamaro89's Avatar
Dave, if the shop had your tranny out, they probably also had you transfer case out or at least was close to it. They could have bumped or hit that 4wd switch motor on the transfer case and that could be it, if that is where the problem is and not at the wheels. Cause the transfer switch motor could be partially engaging the 4wd causeing a grinding, some of these switch motors if not used alot get hung up.
Km, IWE's: Removal & Replacing - F150online Forums
  #236
Old 11-16-2011, 03:43 PM
Stealership called, Axle IWE, solenoids, wheel bearings. to fix it, $1442.50.
It's official, I'm trading it in. I told them to package it back up and not do any work to it. $3700 is enough. They also said the pasengar side exhaust manifold is rotting out and leaking, which is another $1000.
I'm buying a Chevy.
  #237
Old 11-16-2011, 04:00 PM
xjcamaro89's Avatar
I dont know if you have the tools, or if its worth it to you , but you could probably do the wheel bearings and IWEs all in one shot for probably around $600 if you bought the parts and did the work yourself.
  #238
Old 11-16-2011, 04:18 PM
60DRB's Avatar
only one solenoid, about $30
two IWEs, about $160...
  #239
Old 12-03-2011, 09:11 AM
Miami06FX4 Miami06FX4 is offline
Miami06FX4 is starting off with a positive reputation.
IWE replacement
Does anybody market a manual hub replacement for the iwe on the f150? Ive seen upgrades for the 250 & 350's. Going back to manual mechanical hubs makes life a whole lot easier.
  #240
Old 12-03-2011, 09:21 AM
Buy a product from "Gov Motors" NEVER! I know it gets frustrating when a problem arises and a solution is not easy or cheap, but it happens with all makes and models. 27 years in the HD truck business, I have managed service Depts for many years. Believe me when I tell you that I have heard the same stories. We lost many customers to Peterbuilt and Freightliner when Mack had camshaft issues back in the early 2000's, guess what, they had their own issues and those customers have gravitated back to either Mack or Volvo. Ford, Chevy, it's what tickles your fancy, like in my case, I love the Ford exterior and interior finish and politics.
2004 FX4 Four Wheel Drive NOT WORKING!! Capt No Slack 2004 - 2008 F150 2 01-06-2017 08:58 PM
IWE actuaters strat875 Modular V8 (4.6L, 5.4L) 0 11-28-2015 11:12 PM
2010 IWE Grinding Noise. Yes another one, but please look. krazybones 2009 - 2014 F150 23 03-04-2015 09:24 PM
4WD vacuum line '98 Ranger PUZZLED gpdickert Ranger & B-Series 1 07-04-2013 10:01 PM
2007 Expedition iwe repair or replacement. Jeff in Squamish 2007 - 2014 Expedition & Navigator 4 12-26-2012 12:07 PM
Tags
2005, 2006, 4x4, actuator, bad, buy, f150, ford, hub, iwe, online, problems, solenoid, symptoms, system, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
