How Do I Install A New Radius Arm Bushing? - Ford Truck Enthusiasts Forums
Old 03-29-2009, 11:56 AM
rutang's Avatar
rutang rutang is offline
rutang is starting off with a positive reputation.
Hi, I just bought a 1992 Ford Explorer and when I brake or hit a hard bump it really makes a loud clunk sound... the po said it was in need of a radius arm bushing. I have never installed one of these? Is it hard to do? Is there a difference in what brand I should buy? I see schucks has some for $13.99 I can pick up today and from there they go all the way up to $41.99. Thanks for your help.
Old 03-30-2009, 03:09 PM
marragtop's Avatar
marragtop marragtop is offline
marragtop is starting off with a positive reputation.
There are many posts that cover this. Do a search on Radius arm bushings. The parts are cheap, but there is a fair amount of labor involved. If they are the original bushings, then you probably have the pop rivet setup which means they will need to be drilled. You'll know what I'm referring to once you read some of the posts.
How do I change radius arm bushings? LITTLE BLACK TRUCK 1973 - 1979 F-100 & Larger F-Series Trucks 27 08-13-2015 03:30 PM
Radius arm bushing? miafcowboy 1987 - 1996 F150 & Larger F-Series Trucks 3 10-09-2010 09:07 AM
radius arm bushing for 67 f100 kbak 1967 - 1972 F-100 & Larger F-Series Trucks 6 12-21-2006 07:03 AM
Radius arm Bushing Rstrause Brakes, Steering, Suspension, Tires, & Wheels 4 11-10-2004 12:57 PM
radius arm bushing replacement warema 1978 - 1996 Big Bronco 10 12-08-2003 11:00 PM
Tags
1992, 1995, 4x4, 92, arm, bushing, bushings, explorer, f150, ford, install, installing, radius, ranger, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
