Go Back   Ford Truck Enthusiasts Forums > Misc. > Clutch, Transmission, Differential, Axle & Transfer Case
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 03-28-2009, 07:01 PM
rpm9001 rpm9001 is offline
Garage is empty, add now
rpm9001 is starting off with a positive reputation.
4r70w no forward gears, only reverse. help needed..
I have used this site for a long time but this is my first time having to post.
I have a 98 expedition with a 4.2 liter 4x4 and what I believe to be a 4r70w transmission (u code on the door sticker)
The original transmission went at 105k miles and was replaced with a new factory ford transmission by a ford dealer 3.5 years ago ($3800!)
the new transmission only has 10k miles on it.
Now the new transmission only has reverse. reverse works like normal but no forward gears. the idle will change when i put if in gear, but will not move, acts like it is in N . there is no strange noises,,
It's hard to believe a new trany is shot already, no towing, or off road use.
My question is : is there ANYTHING that can go bad that would cause this? The trany fluid is clean and clear bright red, and no burnt smell.
I want to check everything I can before calling a tow truck to have it looked at. I will have it repaired if needed, but I don't think I want to replace another tranny. Please any help would be great.
ps..
If there is a someone who repairs transmissions and has a lot of experance repairing this transmission and would not mind a 5 minute phone call from me please email me at rpm90001@hotmail.com
  #2 (permalink)
Old 03-28-2009, 10:24 PM
jk080's Avatar
jk080 jk080 is offline
Gear Head
2005 Ford F-Super Duty
jk080 has a good reputation on FTE.jk080 has a good reputation on FTE.jk080 has a good reputation on FTE.
To answer the question is there anything that can cause this, is yes there are a few failures that I can think of, but unfortunately they all have to with the forward drum and all of them will require the transmission to be removed and be repaired "rebuilt". Most of the transmission failures I see come through my shop are due to part failure and they can happen at anytime regardless of mileage. You should be able to find a shop to rebuild this transmission with all the goodies for 2 to 2500.00 with a warranty.
__________________
05 Superduty FX4
6 inch lift with Toyo Open Country 38s, 5 inch stainless exhaust, SCT tuner, ARP head studs, EGR delete.
Master Certified Transmission Rebuilder of 25 years of all Makes and Models
Transmission Shop Owner and Operator
  #3 (permalink)
Old 03-28-2009, 10:57 PM
expy37at expy37at is offline
expy37at is starting off with a positive reputation.
I wonder if your problem might be electrical, given that reverse works.
I'd start by inspecting the gear shifting switch/shifter cable assembly on the side of the transmission.
Then pull the codes, maybe a clue there.
Next maybe something in the solenoid pack or valve body.
Drain the fluid and see if there are metal particles and inspect the filter. If no metal, might not be a mechanical failure.
It might be something simple that will make a transmission guy a lot of money -at your expense.
Did the failure happen all at once or were there warning signs, you didn't say.
  #4 (permalink)
Old 03-29-2009, 12:22 AM
In other words, ask for info on what CONTROLS the forward drum.
Solenoid, valve, etc.
  #5 (permalink)
Old 03-29-2009, 07:32 AM
Thank you,
I fell better that I have not I we looked something simple. What should be "updated" while it's apart? I don't want to do this again.
Thanks again for the help
  #6 (permalink)
Old 03-29-2009, 08:22 AM
foreverford1968 foreverford1968 is offline
foreverford1968 is starting off with a positive reputation.
Hi I have the same problem as you on my "99" F-250. have you had any luck finding your problem, If so I would like to hear your sollution please thanks
  #7 (permalink)
Old 03-29-2009, 12:54 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
The manual valve controls it. Just like the manual valve controls the reverse engagement.
There is nothing electrical that can cause it to have reverse and not forward. Listen to the guy that rebuilds them, he knows.
__________________
Mark
Former Ford Automatic Transmission Engineer
“The good thing about science is that it's true whether or not you believe in it.” ― Neil deGrasse Tyson
  #8 (permalink)
Old 03-29-2009, 03:45 PM
THEN, what controls the manual valve?
Is it a linkage or an electrically operated do-hickey?
Or is it something else?
Let's put some TRANSPARENCY on this issue instead of keeping a big dark secret so the 2 guys have to spend big $$$$$$$$$ at a tranny shop.
We have 2 people here who need help.
Any links to the "manual valve" that 'controls' the "forward drum" so we can see what it's all about?
  #9 (permalink)
Old 03-30-2009, 08:36 AM
I'm sorry, I wasn't expecting to go to Transmissions 101 for people that are taking apart a transmission.
The manual valve is a machined aluminum spool valve located inside the valve body. It is mechanically connected to the shift linkage. It is not electronically controlled.
If the transmission shifts in and out of reverse you can be pretty sure that the manual valve is moving when the shifter handle is moved. If it didn't reverse wouldn't work, either.
In order to make a forward engagement the manual valve has to be moved to where it sends hydraulic pressure to the forward clutch, which is what the forward drum houses. Even if the electronics are completely disconnected from the trans the forward clutch would come on if the manual valve sends pressure to it.
Since another expert (probably correctly) diagnosed that the forward drum has failed, I can speculate that when the hydraulic pressure is sent to the forward clutch the broken drum is allowing the pressure to spray out into the pan instead of applying the forward clutch.
__________________
Mark
  #10 (permalink)
Old 03-30-2009, 01:01 PM
Mark, this is what I'm getting at.
IIRC, this issue of a MANUAL LINKAGE in an Expedition has been brought up before.
IIRC there IS NO MANUAL LINKAGE into the xmission in this application.
It is all electrical, controlled by a driver shifting linkage to a multiposition switch on the side of the xmission. As I understand, from there it is all electrical thru a connector into the xmission.
Possibly the connector could be making a bad contact.
That said, I stand to be corrected.
  #11 (permalink)
Old 03-30-2009, 01:07 PM
Also, if the drum were broken, couldn't it be quickly diagnosed confirmed bad/good with a transmission pressure test guage at the appropriate port?
  #12 (permalink)
Old 03-30-2009, 01:41 PM
jk080's Avatar
Gear Head
The following pictures proves just how manual the manual valve is, there is NO electronics involved with moving the shifter inside the vehicle that pulls the cable that moves the shifter arm on the side of the trans, that moves the linkage on the inside that is directly indexed in the manual valve.
The switch on the outside of the transmission tells the computer what gear has been selected, it does not turn the shaft to the selected gear.
The forward drum can fail or loose forward engagement and still have a good pressure reading in the following ways
A: Burnt clutches
B: Broken snap ring groove
C: Clutch splines stripped out
D: Stripped clutch hub.
__________________
05 Superduty FX4
  #13 (permalink)
Old 03-30-2009, 01:47 PM
jk080's Avatar
Gear Head
Pics of the manual valve and internal linkage
No electronics involved.
His transmission is broke, there is no way around it, pull it out..
The knowledge, time and equipment it takes to properly rebuild transmissions and to stand behind your work is why they cost so much. If everybody could do it in there driveway in a hour it would be a lot cheaper.
__________________
05 Superduty FX4
  #14 (permalink)
Old 03-30-2009, 01:56 PM
Good info JK!
Now we are getting somewhere since this is an educational forum.
And I stand corrected.
Is there anything in the valve body that could fail with these symptoms?
Or could the linkage outside the xmission fail in some way to allow rev but not fwd?
Just seems the OP should check whatever he can before towing his truck away.
  #15 (permalink)
Old 03-30-2009, 02:20 PM
jk080's Avatar
Gear Head
Nope, its broke.....
__________________
05 Superduty FX4
Tags
4r70w, body, expedition, f150, ford, forward, foward, gears, only, rebuilt, reverse, symptoms, transmission, valve, works
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
