2.9L to 4.0L conversion
Old 03-27-2009, 11:45 PM
Embreechristopher's Avatar
Embreechristopher
Embreechristopher is offline
Hi there, me and my father have recently bought a 1991 Ford Ranger pick up 2wd with a 2.9 liter that the idiot we got it from forgot to put oil in it and pulled off a rod cap put it back on and did not tighten the nuts, and he did not understand the gauges. and then ran it that way for two weeks before it finally quit. luckily we were able to salvage the block and heads, and will use it for another Ford project. But me and my dad have put in a 4.0L engine out of a 1994 explorer to replace the 2.9L and have the 4.0L wiring harness to finish the conversion. but the question is can I use a starter out of a 2.9L on a 4.0L?
Old 03-28-2009, 07:41 AM
BSmitty's Avatar
BSmitty
BSmitty is offline
I believe so, not 100% sure but it seems like they will.
Old 03-28-2009, 09:58 AM
Pablo-UA's Avatar
Pablo-UA
Pablo-UA is offline
i belive too, becouse 2.9 tranny fits 4.0 and they share clutch parts too
Old 03-28-2009, 10:49 AM
Lead Head's Avatar
Lead Head
Lead Head is offline
It depends, if you used the 2.9 flywheel, then the 2.9 starter will work. If you used the 4.0 flywheel, you will need the 4.0 starter.
Old 05-20-2021, 06:56 PM
Oldmansblacktoy's Avatar
Oldmansblacktoy
Oldmansblacktoy is offline
Might look at Rock Auto Parts on line catalogue compare what starter numbers match.
Old 05-21-2021, 02:57 PM
My4Fordtrucks's Avatar
My4Fordtrucks
My4Fordtrucks is online now
Received 1,360 Likes on 1,074 Posts
He probably has it figured out by now. The last post was from March 2009. Sometimes you miss the date on the post when responding. It happens…..
Welcome to the forums. There are a lot of people here that can help sort out a problem if you get stuck.
TheLastSwordsMan
Engine Swaps
05-06-2016 05:59 PM
1973dieselhighboy
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
10-04-2015 07:11 PM
country_kyle01
04-18-2015 12:55 AM
shovelhead1
51
02-21-2014 10:28 AM
NitrousAl
04-24-2005 09:02 AM
Quick Reply: 2.9L to 4.0L conversion
