Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > New England Region > Connecticut Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Connecticut Chapter Join Chapter, Leader: StreamlineGT
  #1 (permalink)
Old 03-24-2009, 03:53 PM
7.3 Rocket's Avatar
7.3 Rocket 7.3 Rocket is offline
Non-smoker
Garage is empty, add now
7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future
Gauze Type Air Filters
Quote:
Originally Posted by EricPero View Post
I have a 7.3L Diesel with K&N filter.
--Eric
Ditch the K&N and save yourself money in the long run.
A 6637 filter from NAPA gives you better filtration and more air flow than a K&N.
Head over to the 7.3 forums to learn more about it all.
__________________
-Pete, PAA member #84
  #2 (permalink)
Old 03-24-2009, 06:45 PM
Aerocell4x4's Avatar
Aerocell4x4 Aerocell4x4 is offline
Diesel Van Enthusiast
2006 Ford E-Series Van
Aerocell4x4 has a great reputation on FTE.Aerocell4x4 has a great reputation on FTE.Aerocell4x4 has a great reputation on FTE.Aerocell4x4 has a great reputation on FTE.Aerocell4x4 has a great reputation on FTE.
Pete:
What do you recommend for my van?
I am running with the K&N in my van, and its not like the pickup truck's.
I still have the Ford filter which is made by Racor.
__________________
Dave ~*~ Mods are listed in my Gallery (Updated 03/11/2010)
Former Connecticut Chapter Leader Feb. 06, 2009 to Aug. 22, 2010.
2006 E35Q 6.0 5R110 35.4" Tires & 5.13 Diff., Unicell's Aerocell SRW body with Quigley 4x4 Conversion - - - 2004 Expedition XLT 5.4L 4X4 4R75W 3.73 Posi
Prior: Courier Pickup and a 1991 Crown Victoria Interceptor
  #3 (permalink)
Old 03-24-2009, 07:36 PM
7.3 Rocket's Avatar
Non-smoker
Quote:
Originally Posted by Aerocell4x4 View Post
Pete:
I dunno what to do with the vans especially since you've got a 6.uhoh
I only know what to do with the 7.3 Stroker.
You could go up to the 6.0 diesel section and ask around for a recommendation on an intake.
I just know that some guys who were running the K&N had problems with dirt getting through the filter and messing up their turbos. Replaced the turbo and replaced the K&N with a 6637 and they had no problems.
__________________
  #4 (permalink)
Old 03-24-2009, 09:50 PM
Zookie400's Avatar
Zookie400 Zookie400 is offline
Zookie400 is a splendid one to beholdZookie400 is a splendid one to beholdZookie400 is a splendid one to beholdZookie400 is a splendid one to beholdZookie400 is a splendid one to beholdZookie400 is a splendid one to beholdZookie400 is a splendid one to behold
not to totally kill the intro thread......
single layer cotton filters (K&N) are sometimes troublesome, my brother found out the hard way this season and WASTED a race motor. they are perfect and flow very well, however after EVERY cleaning they need to be inspected!!! any disturbance in the single layer filters could mean big holes for dirt to go through. the best way to inspect is by holding it up to a light and look for a new sunroof in your filter. also, if dirt is getting in the first thing to show signs of wear will be the edges of the fins on the turbo compressor wheel, they will erode away.
the dual and triple layer cotton filters are basically the same as oiled foam, and are much more "reliable". i may be wrong, but i believe AFE uses a triple layer oiled cotton. i do know that after last year we tossed 4 k&n's, and my brother lost an engine because he neglected to inspect one that had a big window in it. we are switching back to oiled foam for our race quads, the price of K&N is too much to end up in the garbage halfway through the season.
HIJACK OFF.
__________________
Since light travels faster than sound, some people appear bright until
you hear them speak.
MY YOUTUBE VIDEOS
  #5 (permalink)
Old 03-26-2009, 08:55 PM
Guys:
As you can see I had the Moderator relocate our discussion of filters from the Introduction thread.
Was a good idea you had Aaron
__________________
  #6 (permalink)
Old 03-26-2009, 09:31 PM
As I have a Van I seem to be limited to either the K&N filter or the Racor that Ford uses.
My K&N is a flat panel filter that fits the original air box.
I haven't found another brand flat panel gauze air filter, nor a Cold Air kit with which I could then mount a conical gauze filter.
With my old pair of 6.5's I had AMS Oil foam filters, AMS doesn't have a foam filter for my van.
Such it is.
I have read in the forum that the gauze filters only make a difference at high air flows.
Iirc, somewhere about 80% of engine design air flow does the OEM Racor filter become restrictive.
The posts, as I recall, said that for daily unload driving stay with the OEM Racor element, and only when loaded down / towing to swap out to the gauze.
Ditto for back-country graded roads, run with the OEM Racor, till you get back to civilization (pavement).
__________________
  #7 (permalink)
Old 03-26-2009, 10:31 PM
Zookie400's Avatar
i will say that for the past 20 years of my life my father has run K&N's on the RV's including the current v-10, and they all performed beautifully.
i dont know about the vans, but i heard that the stock air filter setup for the superduties and OBS 7.3 trucks were able to sustain 300hp before you started to see negative pressure in the pre-turbo intake. this is just what i HEARD, so take it how you will. its a plausible claim i think.
dave i am surprised there isnt a larger aftermarket selection for you, i never looked but i assumed there would be more. an email to AFE or another company may get you a replacement filter that you dont see listed anywhere...maybe?
__________________
MY YOUTUBE VIDEOS
  #8 (permalink)
Old 03-27-2009, 02:42 PM
Towmanjbo's Avatar
Towmanjbo Towmanjbo is offline
1992 Ford F-150
Towmanjbo has a great reputation on FTE.Towmanjbo has a great reputation on FTE.Towmanjbo has a great reputation on FTE.Towmanjbo has a great reputation on FTE.Towmanjbo has a great reputation on FTE.
[quote=Zookie400;7312421]
dave i am surprised there isnt a larger aftermarket selection for you, i never looked but i assumed there would be more. [quote]
Not really that suprising, most vans sold these days are work vans (fleet) or already customized (conversion) very few are sold (plain) to customers. The van craze basicly died in the early 80's. Employees are rarely allowed to customize their work trucks and familys who buy conversion vans generaly don't touch them either. There are the die hard van people out there but they are in the minority.
__________________
Justin
  #9 (permalink)
Old 03-27-2009, 03:53 PM
Quote:
Originally Posted by Towmanjbo View Post
...There are the die hard van people out there but they are in the minority.
My first pickup truck was a Ford Courier, and I had a fiberglass cap on it and so it might as well have been a van.
My second pickup truck was a Dodge Dakota 4x4 standard cab because I couldn't afford a 4x4 conversion van.
I had a small job box in the back and it was always wet inside from condensing humidity and rain water seepage.
My third pickup truck was a GMC Sierra 6.5 diesel 4x4 standard cab because I couldn't afford a 4x4 conversion van.
I bought a 'weather-tight' RV box for the bed and the rain never go inside but the snow for some reason always managed to infiltrate the box.
Now I have my van and I discovered that the design of the lift-gate seal allows water to drip inside and so I have to stow everything that I want to keep dry forward of the drip-line plus when there is snow on top of the van and I open the lift-gate its like a pine tree shedding snow into the back
Oh well, always thankful - but - never satisfied
__________________
Tags
73, acwettedgauzeelementaircleanerconversion, air, filter, ford, gauze, triple
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
