Removing headliner on a Crew cab? - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 03-26-2009, 09:42 PM
bigtimebubba bigtimebubba is offline
bigtimebubba is starting off with a positive reputation.
How Do I remove the headliner on a crew cab?
I have read that you can squeeze the headliner out one of the doors, and I have read that the only way to get the headliner out is to remove the rear window.
So how do I get it out, and how do I remove the rear window if that is what is needed?
Thanks
Bubba
Old 03-26-2009, 10:11 PM
miller_feed's Avatar
miller_feed miller_feed is offline
Hook it, I'll pull it.
miller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputation
When I had the dealer do my clearance lights on my '99, they didn't take the head liner out of the truck. They said it can't come out, they didn't say anything about the back window. They had to work around it still in the cab. I don't know.
Old 03-26-2009, 10:18 PM
beanhead6D5's Avatar
beanhead6D5 beanhead6D5 is offline
beanhead6D5 is a name known to allbeanhead6D5 is a name known to allbeanhead6D5 is a name known to allbeanhead6D5 is a name known to allbeanhead6D5 is a name known to allbeanhead6D5 is a name known to all
Bubba,what I have read,taking out the back glass was earier.I don't know about fitting it out the door.
Good luck!!
Old 03-26-2009, 11:00 PM
WideOpenFord's Avatar
WideOpenFord WideOpenFord is offline
WideOpenFord is starting off with a positive reputation.
yea front or rear window is the only way your getting it out. at the salvage yard we take out the windshield if someone buys the headliner.
Old 03-26-2009, 11:29 PM
How do I remove the rear window?
Old 03-27-2009, 09:33 AM
F250_'s Avatar
F250_ F250_ is offline
F250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputation
Here is the Removal and Re-installation details.
Old 03-27-2009, 11:54 AM
RedBoat's Avatar
RedBoat RedBoat is offline
Rather Be Floatin
RedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to behold
I took mine out throught the drivers door, dropped it turned it 90 degrees and angled out the drivers door. This was with the seats still in the truck too.
Old 03-27-2009, 12:29 PM
F250_'s Avatar
The only reason I've heard that the window needs to be removed is because there is a veyr high liklihood of creasing the liner when trying to get it through the door openings. Sounds like you were one of the lucky ones, Costa (or did you nd up with one of those creases?).
Old 03-27-2009, 01:30 PM
DieselBeast01's Avatar
DieselBeast01 DieselBeast01 is offline
DieselBeast01 is gaining momentum as a positive member of FTE.
Why exactly are you removing the headliner? I would say that you have to remove the front or back glass.
Old 03-27-2009, 03:16 PM
RedBoat's Avatar
Rather Be Floatin
Quote:
No creases actually came out without a problem. Guess I was just one of the lucky ones!
Old 03-27-2009, 04:19 PM
Quote:
I'm wrapping it with charcoal microsuede. the headliner right now is a little dirty and a darker charcoal will go much better with the interior. plus make it a little darker inside which will be nice.
Redboat is correct. I just got the headliner out and you do not need to remove the glass. I did remove the front seats just to make it easier on myself but it came right out, just need to gget the angles right.
Now need to put the suede on and then install everything bakc up again
OBS Crew Headliner Removal with Photos kmjone00 1994.5 - 1997 7.3L Power Stroke Diesel 6 08-20-2016 07:13 PM
Headliner and Seat Belts. jvmcc 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 07-03-2016 11:05 AM
water leak from roof some where. cecilj Excursion - King of SUVs 12 11-13-2015 11:52 PM
99-Lariat-F350 Crewcab-headliner ?? Texas Charlie 1999 - 2003 7.3L Power Stroke Diesel 8 09-07-2012 07:16 PM
headliner removal super cab aliasmax 2009 - 2014 F150 0 10-04-2009 12:33 PM
Tags
1999, 2002, 2003, 2008, cab, crew, door, f150, f250, f350, ford, fourms, glass, headliner, pickup, rear, removal, remove, removing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
