Brake rubbing issue!
I had a rubbing issue on my truck which wore my pads down to nothing on the passenger side. I thought the caliper locked out so i changed it. I changed the pads rotor and caliper and it still rubs and grabs quite hard any ideas on why this all of a sudden happened.
It looks like a clearence issue because the caliper bracket looks to close to the rotor compared to the driver side. What might cause this? loose front end? Any ideas will help thanks Jeremy.
i may try that but the problem i seem to be having is that the bracket itself looks like it does not have enough clearance and my rotor includes the studs for the wheels so i have to pull the whole hub take it off. Is there a way if i tightend it o to tight that it would be to close to the bracket?
tjc transport
11-08-2015 08:50 AM
