Torque specs
Hey guys, looking for torque specs on 99 7.3 f-250. Installing 2.5 inch leveling kit in front and naturally no torque specs with kit. I need to know Shackles,Spring bolts, and u-bolts etc... if any would could tell me where to find this info online id appreciate it. Thanks
<table border="1" cellSpacing="0" cellPadding="3"><tbody><tr><th vAlign="bottom" align="center">Description</th><th vAlign="bottom" align="center">Nm</th><th vAlign="bottom" align="center">Lb/Ft</th><th vAlign="bottom" align="center">Lb/In</th></tr><tr><td vAlign="top" align="left">Front Spring-to-Axle U-Bolts</td><td vAlign="top" align="center">133</td><td vAlign="top" align="center">99</td><td vAlign="top" align="center">—</td></tr><tr><td vAlign="top" align="left">Front Spring-to-Spring Hanger Nut</td><td vAlign="top" align="center">350</td><td vAlign="top" align="center">259</td><td vAlign="top" align="center">—</td></tr><tr><td vAlign="top" align="left">Front Spring-to-Shackle Nut</td><td vAlign="top" align="center">250</td><td vAlign="top" align="center">185</td><td vAlign="top" align="center">—</td></tr><tr><td vAlign="top" align="left">Spring Hanger-to-Frame Bolts</td><td vAlign="top" align="center">103</td><td vAlign="top" align="center">76</td><td vAlign="top" align="center">—</td></tr><tr><td vAlign="top" align="left">Spring Shackle-to-Frame Nut</td><td vAlign="top" align="center">250</td><td vAlign="top" align="center">185</td><td vAlign="top" align="center">—</td></tr><tr><td vAlign="top" align="left">Stabilizer Bar-to-Front Spring Spacer Bolts (LH Side Only)</td><td vAlign="top" align="center">47</td><td vAlign="top" align="center">35</td><td vAlign="top" align="center">—</td></tr><tr><td vAlign="top" align="left">Stabilizer Bar-to-Axle Assembly Bracket Bolts (RH Side Only)</td><td vAlign="top" align="center">47</td><td vAlign="top" align="center">35</td><td vAlign="top" align="center">—</td></tr><tr><td vAlign="top" align="left">Stabilizer Bar-to-Link Nut</td><td vAlign="top" align="center">80</td><td vAlign="top" align="center">60</td><td vAlign="top" align="center">—</td></tr><tr><td vAlign="top" align="left">Stabilizer Bar Link-to-Bracket Nut</td><td vAlign="top" align="center">80</td><td vAlign="top" align="center">60</td><td vAlign="top" align="center">—</td></tr><tr><td vAlign="top" align="left">Front Shock-to-Upper Shock Bracket Nut</td><td vAlign="top" align="center">103</td><td vAlign="top" align="center">76</td><td vAlign="top" align="center">—</td></tr><tr><td vAlign="top" align="left">Front Shock-to-Front Spring Spacer Nut</td><td vAlign="top" align="center">103</td><td vAlign="top" align="center">76</td><td vAlign="top" align="center">—</td></tr><tr><td vAlign="top" align="left">Jounce Bumper-to-Frame Bolts</td><td vAlign="top" align="center">40</td><td vAlign="top" align="center">30</td><td vAlign="top" align="center">—</td></tr><tr><td vAlign="top" align="left">Shock Absorber Upper Mounting Bracket-to-Frame Bolts</td><td vAlign="top" align="center">103</td><td vAlign="top" align="center">76</td><td vAlign="top" align="center">—</td></tr><tr><td vAlign="top" align="left">Trackbar-to-Upper Mounting Bracket Nut</td><td vAlign="top" align="center">174</td><td vAlign="top" align="center">129</td><td vAlign="top" align="center">—</td></tr><tr><td vAlign="top" align="left">Trackbar-to-Lower Mounting Bracket Nut</td><td vAlign="top" align="center">174</td><td vAlign="top" align="center">129</td><td vAlign="top" align="center">—</td></tr><tr><td vAlign="top" align="left">Shackle Bracket Assembly-to-Frame Bolts</td><td vAlign="top" align="center">87</td><td vAlign="top" align="center">65</td><td vAlign="top" align="center">—</td></tr><tr><td vAlign="top" align="left">Stabilizer Bar Bracket-to-Frame Bolts</td><td vAlign="top" align="center">47</td><td vAlign="top" align="center">35</td><td vAlign="top" align="center">—</td></tr><tr><td vAlign="top" align="left">Front Driveshaft-to-Pinion Flange Bolts</td><td vAlign="top" align="center">102</td><td vAlign="top" align="center">76</td><td vAlign="top" align="center">—</td></tr><tr><td vAlign="top" align="left">Front Hub and Bearing-to-Knuckle Nuts</td><td vAlign="top" align="center">74</td><td vAlign="top" align="center">55</td><td vAlign="top" align="center">—</td></tr><tr><td vAlign="top" align="left">Tie Rod End-to-Front Knuckle Nut</td><td vAlign="top" align="center">70</td><td vAlign="top" align="center">52</td><td vAlign="top" align="center">—</td></tr><tr><td vAlign="top" align="left">Vacuum Valve Mounting Bolts</td><td vAlign="top" align="center">11</td><td vAlign="top" align="center">—</td><td vAlign="top" align="center">98</td></tr><tr><td vAlign="top" align="left">Lower Ball Joint Nut</td><td vAlign="top" align="center">136</td><td vAlign="top" align="center">101</td><td vAlign="top" align="center">—</td></tr><tr><td vAlign="top" align="left">Upper Ball Joint Nut</td><td vAlign="top" align="center">136</td><td vAlign="top" align="center">101</td><td vAlign="top" align="center">—</td></tr></tbody></table>
tigerfan79
03-06-2016 09:54 PM
flamesoldier
05-21-2013 09:59 AM
64F-100
04-16-2009 06:20 AM
