1961 F250 4x4 Highboy? - Page 5 - Ford Truck Enthusiasts Forums
  #61
Old 10-20-2013, 08:08 PM
ktmduke640 ktmduke640 is offline
ktmduke640 is starting off with a positive reputation.
Could someone decipher the following id number f26jk171366
thanks
  #62
Old 10-20-2013, 08:32 PM
Shadowrider123 Shadowrider123 is offline
Shadowrider123 is starting off with a positive reputation.
If 67+ F250 4X4 frames are all the same, how do they differ from the 65/66 F250 4x4 frames?
Does that mean that the 73+ F250 4x4s did not get the longer box?
  #63
Old 10-20-2013, 09:10 PM
1972RedNeck's Avatar
1972RedNeck 1972RedNeck is online now
1972RedNeck has a good reputation on FTE.1972RedNeck has a good reputation on FTE.
Quote:
They are quite similar. The bottom contour of both frames over the rear axle is the same. Th slicks are flat on top while the later ones have a bit of a bump to keep the rail taller.
  #64
Old 04-11-2014, 01:50 AM
Eric Heal Eric Heal is offline
Eric Heal is starting off with a positive reputation.
Im trying to locate a 1961 F250 4x4 (prefer a high boy). This would be something I would expect to work on and fix up, my intent is to make it a tribute truck to the one my late father had when I was a kid. hope to find something solid Im not set up to do do a rust restore, and my funds are extremely limited but if someone has a lead on this particular vehicle that' running also its not require to have a bed, I intend to put a flatbed on it in the end. my email is ericheal@hotmail.com and also I can be found on facebook. My cell is 207-922-0097 I hope to hear from someone soon, please help me make my tribute truck dream come true, I would love to commemorate my father with this truck, thanks
  #65
Old 04-11-2014, 01:51 AM
Hope someone can help
  #66
Old 04-11-2014, 10:24 PM
If you put a bump body on a dent Highboy frame, the cab to box gap will be about an inch too big if the wheels are properly centered in the wheel wells.
  #67
Old 04-12-2014, 07:23 PM
tripleframe's Avatar
tripleframe tripleframe is offline
tripleframe is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by NumberDummy View Post
The steering column should be painted white to match the dash and steering wheel.
Black is the correct color for American built 61-66 F250 4x4 steering columns, either Standard or Custom Cab.
  #68
Old 11-16-2016, 07:20 PM
Luvdadsford Luvdadsford is offline
Luvdadsford is starting off with a positive reputation.
NumberDummy I'm a new member. Can you breakdown a VIN# for me?
F26CK180933
Highboy Information Compilation zerfetzen 1973 - 1979 F-100 & Larger F-Series Trucks 107 02-07-2017 06:23 PM
1961 4x4 parts truck 1961 f100 4x4 Ford Truck Parts for Sale 1 07-29-2016 08:27 PM
1961 Unibody, More Power? 1961greenmachine 1961 - 1966 F-100 & Larger F-Series Trucks 16 05-19-2016 10:38 AM
1961 radiator support 1961 f100 4x4 WTB - Parts & other 1 10-05-2015 06:13 AM
f100 front and rear axle more 4x4 1961 f100 4x4 Ford Truck Parts for Sale 3 09-29-2015 09:35 PM
Tags
19, 1963, 1973, 4wd, 59, 70, dana, f250, ford, highboy, lug, numbers, pattern, photo, pictures, suspension, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
