1961 F250 4x4 Highboy? - Page 4 - Ford Truck Enthusiasts Forums
  #46
Old 03-28-2009, 01:04 PM
IsoGrifo's Avatar
IsoGrifo IsoGrifo is offline
IsoGrifo is starting off with a positive reputation.
also, anybody in the phoenix area would know where maricopa is, the former mayor of maricopa lives around the corner from me, he's got a 61 f100 uni short bed i've been meaning to save up some money and go make an offer.
  #47
Old 03-28-2009, 03:21 PM
modeleh modeleh is offline
modeleh is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by camperspecial65 View Post
what do the numbers at bottom of decal say..tiny numbers ...I saw a couple of them in the pic...
- cs65
BTW, is that rusty pup still around or do ya know modelah ?
I think the numbers on the decal are 5301-4, the 3 is questionable because there is damage to the decal in that spot.
As for the other truck, I'm sure it's probably still there, although I haven't been for a drive past his house since I went to take the pics for you. That one would be a big project for someone who didn't have a good cab lying around.
  #48
Old 03-28-2009, 05:46 PM
61F250Highboy's Avatar
61F250Highboy 61F250Highboy is offline
61F250Highboy is starting off with a positive reputation.
Does anybody have a semi-slick place to put in a CD player? My truck had an AM/FM radio in it, so there is already a hole in the dash, but i don't really feel like cutting up the poor truck any more than it is... unless the dash's are easy to find.
  #49
Old 03-28-2009, 07:32 PM
camperspecial65 camperspecial65 is offline
camperspecial65 has a good reputation on FTE.camperspecial65 has a good reputation on FTE.camperspecial65 has a good reputation on FTE.
glovebox or under the seat...radios are best there too to prevent hacked up dashes...just for future reference.
- cs65
  #50
Old 03-28-2009, 07:57 PM
Do you have any ideas as to how to patch up the hole in the dash?
  #51
Old 03-29-2009, 02:51 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by 64f2504x4 View Post
any chance you have numbers on 64 styleside 292.
There is no production figure breakdowns for: engines, Custom Cabs, Camper Specials, Rangers, Long/Short Wheelbases, which truck came with this, which truck came with that.
All that is available is the particular body styles, and if they are 2WD or 4WD.
1964 Styleside
F100: 2WD = 151,272 / 4WD = 2,922
F250: 2WD = 28,104 / 4WD = 2,232
F350 = 1,714
Modeleh: NUMBERS found on decals are FORM NUMBERS.
If you contact Dana, and give them the FORM NUMBER...they still may have some of those decals available.
  #52
Old 03-29-2009, 04:49 PM
Can Anybody ID this Axle?
I've looked around and all the f250's I saw had the 6bolt/screw hub in them, Is it even possible to find out from just looking at the hub?
  #53
Old 03-30-2009, 02:20 AM
Quote:
Bill, thanks for the info on the decal.
Highboy, those hubs you have are aftermarket, you cannot determine axle size with the hub. Good hubs though, no need to change them. It is most likely you have a closed knuckle Dana 44. From underneath the front of the truck, look at the steering knuckles, you'll probably see spherical ***** at each end of the axle tube, that indicates a closed knuckle design. Look at the size of the front diff cover plate and compare it to the rear diff cover. If the front one is smaller, it'll be Dana 44, if it's the same then it's a 60, but that'd surprise me.
  #54
Old 03-30-2009, 03:27 AM
Quote:
Originally Posted by modeleh View Post
Highboy, those hubs you have are aftermarket..
While these are WARN hubs, Ford offered them as an optional accessory available either factory installed or at the parts counter.
COTZ1104A .. WARN Hub-Free Running-Manual Locking.
Fits: 1959/65 F100/250 4WD w/3M Front Axle.
Additional WARN Hubs:
C6TZ1104B .. WARN Hub-Free Running-Manual Locking / Models: M167; M185.
Fits: 1966/72 F100/250 4WD w/3M Front Axle.
C6TZ1104F .. WARN Hub-Free Running-Lock-o-Matic / Model M175.
C9TZ1104B .. WARN Hub-Free Running-Manual Locking / Models: M166; M197.
Fits: 1967/72 F250 4WD w/3.5M Front Axle.
1961/66 F100/250 4WD. Ford offered two different Dana Front Axles:
Dana 44-6F (3M) With or Without Free Running Hubs.
Dana 44-6FH/D (3.5M) With or Without Free Running Hubs.
  #55
Old 03-30-2009, 05:10 AM
My friends 64 had those same hubs...D60s front and rear...a real beast offroad as it was used as a wood hauler...I remember helping him rebuild the front end on it...my first, one and only experience with rebuilding a 4WD front end...I also remember the hubs were a pain to lock in/out at times before the rebuild...not much room for mansize fingers...let alone teenage boys like I and my friend were at the time...
Ahhh..the good ole days.....
- cs65
  #56
Old 03-30-2009, 06:09 AM
My friends 64 had those same hubs...D60s front and rear...a real beast offroad as it was used as a wood hauler...I remember helping him rebuild the front end on it...my first, one and only experience with rebuilding a 4WD front end...I also remember the hubs were a pain to lock in/out at times before the rebuild...not much room for mansize fingers...let alone teenage boys like I and my friend were at the time...Ahhh..the good ole days.....- cs65
Ahhh...the good old days, but Dana 60's front axles were not available in 1964. In fact...
1959/72 F100/250 4WD: Dana 44's only. 1964/72: There are six variations.
Text: Section 40A, parts lists 135-140.
Yeah...I know that 40A is the rear axle parts list section, but that's where Ford put the front axle parts lists from 1959 thru 1972.
  #57
Old 03-30-2009, 06:32 AM
Was that on the 3/4 ton trucks as well Bill...No D60s...I forgot to mention thats what my friends was...my bad..
- cs65
  #58
Old 03-30-2009, 11:56 AM
[quote=NumberDummy;7323930]While these are WARN hubs, Ford offered them as an optional accessory available either factory installed or at the parts counter.
Good to know. Thanks for that one too. I was thinking of getting rid of the old 3 bolt Dana hubs I have because they are a poor design IMO, nice to know I won't be "modifying" it if I put Warn hubs in. lol. I knew the newer trucks used Warn stuff as my old man had to replace one on an '86 Ranger, he got the replacement from the Ford dealer and it came in a Warn box, didn't know they were a supplier to Ford from the beginning of the 4x4s though. They had some cool products back in the early days like an accessory overdrive for Jeeps.
  #59
Old 03-30-2009, 12:13 PM
- cs65
I assumed you meant F250's, because...
No Dana 60 front driving axles were ever installed in F100's or F150's, regardless of what year they were.
Did'ja see what I typed in the second sentence of post #56? 1959/72 F100/250 4WD: Dana 44's only.
  #60
Old 03-30-2009, 04:33 PM
Ya...partly anyways it seems...lol...tired eyes overlook things at times...I had thought 60s or 44s were both available...once again Im corrected by ya...Its all good Bill :-)
- cs65
1961 4x4 parts truck 1961 f100 4x4 Ford Truck Parts for Sale 1 07-29-2016 08:27 PM
1961 radiator support 1961 f100 4x4 WTB - Parts & other 1 10-05-2015 06:13 AM
Highboy Information Compilation zerfetzen 1973 - 1979 F-100 & Larger F-Series Trucks 97 04-06-2015 11:28 PM
1961 f100 original tire & wheel size FoMoCoMoFo 1961 - 1966 F-100 & Larger F-Series Trucks 13 12-18-2014 01:36 PM
1976 f150 4x4 highboy Sally Salazar 1973 - 1979 F-100 & Larger F-Series Trucks 33 12-09-2009 12:48 PM
Tags
19, 1963, 1973, 4wd, 59, 70, dana, f250, ford, highboy, lug, numbers, pattern, photo, pictures, suspension, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
